Hello TrueNAS community,
I'm facing an issue with my TrueNAS server after a recent power outage. The server shut down unexpectedly due to the power loss, and since then, my data pool has been showing as offline. I've attempted to restore the connection by disconnecting and reconnecting, but unfortunately, I'm unable to access any data or re-add the pool in TrueNAS.
When I go to the WebUI and navigate to "Storage" -> "Import Pool," I'm encountering the following error message:
This error has been puzzling, and I've been trying to find a solution. I did some research and came across a similar thread on the TrueNAS forums (link: https://www.truenas.com/community/threads/zfs-pool-corrupted.98445/) where a user faced a similar issue. In their case, the solution was to reimport the ZFS pool within the shell. Unfortunately, attempting this method has not resolved my problem.
When I run the command zpool import -f, I get the following output:
"cannot import 'inotank': one or more devices is currently unavailable."
For context, here's the configuration file of my VM-Ware:
Best regards
Long Version - PastebinError importing pool - 2090 is not a valid Error
Additionally, I've tried the command zpool import -f -FX inotank and received the error messagepool: inotank
state: FAULTED
status: One or more devices contains corrupted data.
action: The pool cannot be imported due to damaged devices or data.
The pool may be active on another system, but can be imported using
the '-f' flag.
see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-5E
inotank FAULTED corrupted data
mirror-0 ONLINE
61207036-955f-447d-b85a-c387515d3892 ONLINE
2c5f554c-47f7-41ae-a963-90deeea598a8 ONLINE
indirect-1 FAULTED corrupted data
I would greatly appreciate any insights, suggestions, or guidance to resolve this issue. If you've encountered a similar situation or have expertise with ZFS pools, please share your knowledge. Thank you in advance for your assistance.agent: 1
boot: order=scsi0;net0
cores: 4
memory: 8192
meta: creation-qemu=7.2.0,ctime=1682874672
net0: virtio=96:7F:43:95:5C:FC,bridge=vmbr0
numa: 0
onboot: 1
ostype: l26
scsi0: local-lvm:vm-101-disk-0,iothread=1,size=32G
scsi1: /dev/disk/by-id/ata-ST14000NM000J-2TX103_ZR600TVG,size=13039G
scsi2: /dev/disk/by-id/ata-ST14000NM000J-2TX103_ZR600WMS,size=13039G
scsi3: /dev/disk/by-id/ata-ST16000NM001G-2KK103_ZL2PVF38,size=14902G
scsihw: virtio-scsi-single
smbios1: uuid=73e69195-753a-45f3-af87-4ae7ec9ecac3
sockets: 1
vmgenid: 9dcfe925-168e-443e-ae05-e68d12a62aa1
Best regards
