I have APC 950 and it works with TrueNAS 12 with usb. Here is how todo:
Add new Jail MonitorUPS
with parameters:
Basic Properties
Auto-start
Jail Properties
devfs_rulset: 3
allow_mount_*: allow_mount_devfs
Then start Jail.
Open shell and put commands:
pkg update
pkg install apcupsd
pkg install nano
On trueNAS go to services -> UPS and add:
UPS Mode: Master
Driver: APC ups 3 (various) APCUPSD-controlled
Port or Hostname: 192.168.0.122:3551 <-IP of Jail MonitorUPS
with parameters:
Basic Properties
Auto-start
Jail Properties
devfs_rulset: 3
Then start Jail.
pkg update
pkg install apcupsd
pkg install nano
UPS Mode: Master
2022-01-22 15:56:15 apctest 3.14.14 (31 May 2016) freebsd
Checking configuration ...
: Warning: old configuration file found.
: Expected: "## apcupsd.conf v1.1 ##"
: Found: "#BOF
: Please check new file format and
: modify accordingly the first line
: of config file.
: Processing config file anyway.
sharenet.type =
cable.type = USB Cable
mode.type = USB UPS Driver
apctest FATAL ERROR in apctest.c at line 313
Unable to create UPS lock file.
If apcupsd or apctest is already running,
please stop it and run this program again.
apctest error termination completed
and with apcaccess:
: Found: "#BOF
: of config file.
Error contacting apcupsd @ localhost:3551: Connection refused
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
