SOLVED Need help please-FN 11.2.U5 Unusable Pool-ports using Sata Express (backward to Sata only ports)
1kokies
any advice here is much appreciated. more importantly is software or hardware related
my biggest concern, is there any chance the Freenas config gets embedded to the 8 hard disks ? making it unrecognized which ever hardware changes i make.
That isn't how it works. You can take drives from any pool and plug them into another system running FreeNAS and import them (so long as the FreeNAs versions are compatible). The system config saves certain share settings etc but isn't required to import a new pool and typically isn't stored on your pool.
will re installing and uploading the back up config help ?
I wouldn't necessarily try this right away. If the system is otherwise stable it is likely not the issue.
i have taken out the thermaltake 3503 hard disks bay https://www.thermaltake.com/C_00002934.htm and plug sata all direct to raid card and motherboard ports. with only bad slog, new slog not plugged in.
I don't know anything about this specific bit of hardware but I doubt it is related; it is 3 drives and 3 SATA plugs so likely each has its own plug. Though, it is probably good to just go with the onboard SATA ports.
At this point I'd go through smartctl -a /dev/{device} for every drive in the pool and see what is up. Specifically I'd look for any failing smart tests. If you've never run any smart tests now is a good time to do a long test on those drives. To identify failures look for actual test errors but also look for values > 0 for the following lines.
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
Do you have another FreeNAS machine you could plug these drives into to try to import the pool?
Right now my guess is that the issue is hardware; either that RAID card, some of the drives, or the onoard SATA controller. If we exhaust every option you may want to try to get those drives into a machine without any RAID card whatsoever directly connected via SATA or an HBA and see if you could import them.
1kokies
OK i feel x10 better knowing this and it isn't a software issue, many thanks for this
OK got it, if i do will try on a totally different hardware=processor, motherboard, rams, raid card
yes i have already removed the disks and they are directly plugged to SATA ports
OK i will do this, but just let me try the different hardware to recognize the pools first, i would like that first level of comfort. Here is a screenshot of da0 which is one of the disk
Again x10 felt better if it is hardware issue (assuming not the disks or software issue). yes i do have 2 different machines which i can alternate to plug in to see if the pool is recognized. Will go on the assumption of hardware issue. Let me set up those hardware now and i will post again.
Philo, thanks for this suggestion, let me try it out, will keep posted.
Focus on the mobo and RAID cards first.
SATA ports on your motherboard or via that card?
I would suggest you do this step as soon as you're able. Running the smart tests on your drives may tell us how many are failing or having issues etc.
How are you accessing your terminal? If you're doing it via the GUI could you just highlight the text and copy-paste the values into these forums? It'll save you having to take so many screen shots and truncating results. For example, the image above doesn't include the full output such as test results, or reallocated sector count. It really is best not to truncate information where possible.
1kokies
OK i will, i only have 2 raid cards flashed to IT, the others i have not flashed(will take time). As i have 2 spare mobo (1 which is a lab status, let's call it AMD965 and is already in case ready to deploy). i can move the 8 disks Data Storage pool to this PC and see if the pool is detected for import. if is then all is well and the Asus X99 mobo have a problem. From here i will assemble another production server ( let's call it IntelE2680, couple of hours only), put all the 12 disks + 2 slog, install fresh 11.2 U6, upload config, and hope all goes well. that's my plan, all depends if the Data Storage pool can be recognized by AMD965 for pool import. i have not done a pool import before and current config has lots of settings which i may not be able to repeat.
both, as mobo only has 8 ports and i have 12 hdd + 2 slog. To test both the raid cards i will alternate and plug in Data Media, if this pool is not recognized then i know it's the raid card and which one.
yes i will, i just want to be comfortable that the Data Storage pool is recognized first. if i do smart tests first are we suspecting some disks have totally failed which is why the pool is not recognized ? there are no prior alerts to this. but if this is a real concern then i will do it first and post here for all the 8 disk.
i am doing it via GUI and i have tried to highlight the test and copy-paste to a note pad but it does not work, no option to do that.
1. highlight the text on shell in GUI, right click to copy then right click to paste here, which i can't seem to have option. i am using chrome.
thanks again Philo. will update and feel free to give me directions.
Yes, that is why I want to look at smartctl -a and run long tests. If drives are hosed that would explain your situation.
1kokies
alright i will do the smart test first. can you please guide me on using shell command to do it ?
and i really can't seem to copy & paste shell to here.
1kokies
i just want to be precise with the smart CLI commands for the smart test for the 8 disks, much appreciated.
For things like that you'll find great resources looking to the manual, which is here, or even a good old search of this this forum or googling. In general it is smartctl -t {short|long} {device}. I do encourage you to check the forums for this kind of information though, there are a lot of great resources around here. :)
1kokies
OK but i am not very familiar with this and ran into this problem
1. smartctl -t short /dev/da0 did this
2. smartctl -t long /dev/da0 progress below
[root@freenas ~]# smartctl -t long /dev/da0
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF OFFLINE IMMEDIATE AND SELF-TEST SECTION ===
Sending command: "Execute SMART Extended self-test routine immediately in off-line mode".
Drive command "Execute SMART Extended self-test routine immediately in off-line mode" successful.
Testing has begun.
Please wait 631 minutes for test to complete.
Test will complete after Fri Oct 18 15:37:04 2019
Use smartctl -X to abort test.
[root@freenas ~]#
631 minutes is like too long, then to abort i did smartctl -x /dev/da0. to check if the smart test did stop i did smartctl -t short /dev/da0 and results below
0x06  0x010  4             144  ---  Number of ASR Events
0x06  0x018  4             667  ---  Number of Interface CRC Errors
                                |||_ C monitored condition met
                                ||__ D supports DSN
                                |___ N normalized value
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x000a  2            2  Device-to-host register FISes sent due to a COMRESET
0x0001  2            0  Command failed due to ICRC error
0x0003  2            0  R_ERR response for device-to-host data FIS
0x0004  2            0  R_ERR response for host-to-device data FIS
0x0006  2            0  R_ERR response for device-to-host non-data FIS
0x0007  2            0  R_ERR response for host-to-device non-data FIS
[root@freenas ~]# smartctl -t short /dev/da0
Can't start self-test without aborting current test (90% remaining),
add '-t force' option to override, or run 'smartctl -X' to abort test.
[root@freenas ~]#
what is the CLI to really abort the long smart test for da0 please, would like to abort the long test and continue with the short ones for remaining drives
1kokies
thanks for your patience for the above
1kokies
smartctl -a /dev/da0 returns the below, not sure if the smartctl -t long /dev/da0 still in progress or not
199 UDMA_CRC_Error_Count    0x003e   200   192   000    Old_age   Always       -       178
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       16849 (208 62 0)
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       65529703758
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       46229415874
SMART Error Log Version: 1
No Errors Logged
# 1  Extended offline    Self-test routine in progress 90%     16858         -
# 2  Short offline       Completed without error       00%     16857         -
[root@freenas ~]#
1kokies
did a smartctl -x /dev/da0 again and returned below
0x05  0x048  1              30  ---  Lowest Average Long Term Temperature
0x05  0x050  4               0  ---  Time in Over-Temperature
0x05  0x058  1              70  ---  Specified Maximum Operating Temperature
0x05  0x060  4               0  ---  Time in Under-Temperature
0x05  0x068  1               0  ---  Specified Minimum Operating Temperature
0x06  =====  =               =  ===  == Transport Statistics (rev 1) ==
0x06  0x008  4            1626  ---  Number of Hardware Resets
                                ||__ D supports DSN
has the long smartest stopped or how to completely stop it, can't seem to do it with smartctl -x /dev/da0
The tests can be slow.
To be honest; it is hard to keep up with what you're doing. We go back and forth but between messages sometimes I can't tell if you've done only what has been suggested or a bunch of other commands. When you run a bunch of other commands it makes it hard to know what state you're in and so I feel the need to try to sync up again. It is tempting to panic and try a bunch of stuff but that runs the risk of actually taking longer and possibly messing things up. If you're pool is already in a bad state it is very important that you not accidentally put it in a worse state. This is why I'm being slow with what I'm recommending; because I don't know exactly what state you're in and I don't want to suggest something that will make it impossible for you to get your data back.
I recommend you run long tests on every drive in that pool; they can run in parallel. If you want, you can copy-paste the entire output smartctl -a {device} to get a sense of what state the tests are currently in. The output above is also truncated. Keep in mind that when you use the command line via the GUI long output doesn't fit on one screen and you have to scroll.
It may be that someone with more experience than me will recognize a situation like this more clearly and have better solutions.
Anyway, happy to keep helping, but please try to be as explicit about exactly what you do and provide as much output as you can without truncating results.
1kokies
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       16849 (113 200 0)
No Errors Logged
# 1  Extended offline    Self-test routine in progress 80%     16859         -
[root@freenas ~]#
ok it is progressing from 90% to 80%
1kokies
OK got it and i apologize for this, bottom of my heart. This is the first time i am doing shell CLI so i tend to be confusing.& it's a steep learning curve. but i will do best so that information is correct.
i am not sure how to do long test in parallel therefore i am doing it one by one. On the output being truncated i will learn to scroll to copy. Perhaps after this drive of da0 has completed i will do short tests
You are the best person so far and please continue to be happy ya. i really need your help. Appreciate your patience
Issue the command for each drive individually. The tests run int he background. If you do them 1 by 1 it will take many days. if you do them in parallel they won't take nearly as long.
1kokies
OK let me first learn how to copy & paste the whole output, i see what you mean by truncating, totally agree data are left out.
1. i use new GUI in shell i don't have option to copy & paste, even using Firefox nor chrome
2. i use the legacy GUI in shell, i don't have option to scroll, so i use the PASTE button, which returns below
 Spin_Up_Time            0x0003   093   093   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       540
  7 Seek_Error_Rate         0x000f   090   060   045    Pre-fail  Always       -       904816146
  9 Power_On_Hours          0x0032   081   081   000    Old_age   Always       -       16860 (6 228 0)
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       545
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   001   000    Old_age   Always       -       667
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   056   056   040    Old_age   Always       -       44 (Min/Max 33/44)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       205
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       891
194 Temperature_Celsius     0x0022   044   044   000    Old_age   Always       -       44 (0 21 0 0 0)
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       16850 (179 234 0)
No Errors Logged
# 1  Extended offline    Self-test routine in progress 70%     16860         -
[root@freenas ~]#
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       16850 (143 113 0)
No Errors Logged
there are much more information with the new GUI shell, let me try again.
1kokies
managed to get the output copy with SSH/Putty, think this is better. thanks Philo !
root@freenas:~ # smartctl -a /dev/da0
Model Family:     Seagate IronWolf
Device Model:     ST4000VN008-2DR166
Serial Number:    ZDH1E7MA
LU WWN Device Id: 5 000c50 0a2ca53df
Firmware Version: SC60
User Capacity:    4,000,787,030,016 bytes [4.00 TB]
Rotation Rate:    5980 rpm
Form Factor:      3.5 inches
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Fri Oct 18 07:49:08 2019 +08
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
Self-test execution status:      ( 246) Self-test routine in progress...
                                        60% of test remaining.
data collection:                (  581) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (   1) minutes.
recommended polling time:        ( 631) minutes.
Conveyance self-test routine
SCT capabilities:              (0x50bd) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000f   082   064   044    Pre-fail  Always       -       176119726
  3 Spin_Up_Time            0x0003   093   093   000    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   090   060   045    Pre-fail  Always       -       905038420
  9 Power_On_Hours          0x0032   081   081   000    Old_age   Always       -       16860 (186 67 0)
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       16851 (120 200 0)
No Errors Logged
# 1  Extended offline    Self-test routine in progress 60%     16860         -
root@freenas:~ #
root@freenas:~ #
1kokies
all 8 disks for Data Storage da0-da7, being smart scanned smartctl -t long /dev/daX . will keep posted of results
