Need help investigating Unhealthy Pool - Smartctl errors
bigbrovar
Hello people,
I am new here so I first one to apologies if I break any rules or did something that does not follow the forum etiquette. I read the rules and would follow them to the best of my knowledge, if I make a mistake kindly correct me and I would be guided.
I just completed my first TrueNAS build. The information about the Build is in my signature.
I got an error alert about 2 the disk that make up my Z1 Pool. Interestingly, although the pool was marked as degraded, all the disk that make up the pool were still marked as online. I ran a scrub of the pool and it came out with 0 errors.
Going through previous post here I noticed people with similar issues were advised to run a smart test. I ran a long smartctl test on the 2 drives with the alert and below are the result.
DRIVE 1​
/dev/ada5
root@dune[~]# smartctl -a /dev/ada5
smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p7 amd64] (local build)
Model Family:     Western Digital Red
Device Model:     WDC WD80EFAX-68LHPN0
Serial Number:    2SG6W4DJ
LU WWN Device Id: 5 000cca 27dc3201d
Firmware Version: 83.H0A83
User Capacity:    8,001,563,222,016 bytes [8.00 TB]
Rotation Rate:    5400 rpm
Form Factor:      3.5 inches
ATA Version is:   ACS-2, ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Wed Jul 12 05:45:39 2023 WAT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (   93) seconds.
capabilities:                    (0x5b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 983) minutes.
SCT capabilities:              (0x003d) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000b   100   100   016    Pre-fail  Always       -       0
  2 Throughput_Performance  0x0004   129   129   054    Old_age   Offline      -       112
  3 Spin_Up_Time            0x0007   159   159   024    Pre-fail  Always       -       408 (Average 420)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       157
  5 Reallocated_Sector_Ct   0x0033   100   100   005    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000a   100   100   067    Old_age   Always       -       0
  8 Seek_Time_Performance   0x0004   128   128   020    Old_age   Offline      -       18
  9 Power_On_Hours          0x0012   099   099   000    Old_age   Always       -       9627
 10 Spin_Retry_Count        0x0012   100   100   060    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       157
 22 Helium_Level            0x0023   100   100   025    Pre-fail  Always       -       100
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       815
193 Load_Cycle_Count        0x0012   100   100   000    Old_age   Always       -       815
194 Temperature_Celsius     0x0002   154   154   000    Old_age   Always       -       42 (Min/Max 24/52)
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0022   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0008   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x000a   200   200   000    Old_age   Always       -       24
SMART Error Log Version: 1
ATA Error Count: 24 (device log contains only the most recent five errors)
        CR = Command Register [HEX]
        FR = Features Register [HEX]
        ER = Error register [HEX]
        ST = Status register [HEX]
Error 24 occurred at disk power-on lifetime: 8850 hours (368 days + 18 hours)
  ER ST SC SN CL CH DH
  84 51 20 97 20 d5 40  Error: ICRC, ABRT 32 sectors at LBA = 0x00d52097 = 13967511
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  25 00 00 b8 1f d5 40 08   4d+00:04:52.634  READ DMA EXT
  ef 02 00 00 00 00 40 08   4d+00:04:52.611  SET FEATURES [Enable write cache]
  ef aa 00 00 00 00 40 08   4d+00:04:52.608  SET FEATURES [Enable read look-ahead]
  c6 00 10 00 00 00 40 08   4d+00:04:52.607  SET MULTIPLE MODE
  ef 10 02 00 00 00 40 08   4d+00:04:52.604  SET FEATURES [Enable SATA feature]
Error 23 occurred at disk power-on lifetime: 8850 hours (368 days + 18 hours)
  84 41 00 00 00 00 00  Error: ICRC, ABRT at LBA = 0x00000000 = 0
  60 00 90 78 36 d4 40 08   4d+00:04:37.442  READ FPDMA QUEUED
  61 40 d8 38 33 d4 40 08   4d+00:04:37.430  WRITE FPDMA QUEUED
  61 40 d0 b8 35 d4 40 08   4d+00:04:37.429  WRITE FPDMA QUEUED
  61 40 c8 78 35 d4 40 08   4d+00:04:37.428  WRITE FPDMA QUEUED
  61 10 c0 90 02 40 40 08   4d+00:04:37.427  WRITE FPDMA QUEUED
Error 22 occurred at disk power-on lifetime: 8850 hours (368 days + 18 hours)
  60 d8 70 a0 85 d3 40 08   4d+00:04:26.236  READ FPDMA QUEUED
  61 40 e8 a0 83 d3 40 08   4d+00:04:26.225  WRITE FPDMA QUEUED
  61 80 e0 e0 7d d3 40 08   4d+00:04:26.224  WRITE FPDMA QUEUED
  61 08 d8 00 8f 82 40 08   4d+00:04:26.223  WRITE FPDMA QUEUED
  61 40 d0 60 85 d3 40 08   4d+00:04:26.223  WRITE FPDMA QUEUED
Error 21 occurred at disk power-on lifetime: 8850 hours (368 days + 18 hours)
  60 00 d8 e0 15 d2 40 08   4d+00:04:03.006  READ FPDMA QUEUED
  60 40 e8 20 22 d2 40 08   4d+00:04:02.979  READ FPDMA QUEUED
  60 c0 e0 e0 1d d2 40 08   4d+00:04:02.979  READ FPDMA QUEUED
  ef 02 00 00 00 00 40 08   4d+00:04:02.976  SET FEATURES [Enable write cache]
  ef aa 00 00 00 00 40 08   4d+00:04:02.973  SET FEATURES [Enable read look-ahead]
Error 20 occurred at disk power-on lifetime: 8850 hours (368 days + 18 hours)
  60 40 f0 68 06 74 40 08   4d+00:00:25.006  READ FPDMA QUEUED
  60 40 e8 28 06 74 40 08   4d+00:00:25.003  READ FPDMA QUEUED
  60 40 e0 e8 05 74 40 08   4d+00:00:25.000  READ FPDMA QUEUED
  60 40 d8 68 05 74 40 08   4d+00:00:24.897  READ FPDMA QUEUED
  60 40 d0 a8 05 74 40 08   4d+00:00:24.893  READ FPDMA QUEUED
# 1  Extended offline    Completed without error       00%      9621         -
# 2  Extended offline    Completed without error       00%      9413         -
# 3  Extended offline    Completed without error       00%      9268         -
# 4  Short offline       Completed without error       00%       206         -
# 5  Short offline       Completed without error       00%       200         -
# 6  Short offline       Completed without error       00%       197         -
DRIVE 2​
/dev/ada0
root@dune[~]# smartctl -a /dev/ada0
Model Family:     HGST Deskstar NAS
Device Model:     HGST HDN728080ALE604
Serial Number:    VLKWAZ0Y
LU WWN Device Id: 5 000cca 260f6b5b4
Firmware Version: A4GNW91X
Rotation Rate:    7200 rpm
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Wed Jul 12 09:02:57 2023 WAT
                                        been run.
data collection:                (  101) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        (1159) minutes.
  2 Throughput_Performance  0x0005   134   134   054    Pre-fail  Offline      -       105
  3 Spin_Up_Time            0x0007   150   150   024    Pre-fail  Always       -       452 (Average 427)
  4 Start_Stop_Count        0x0012   099   099   000    Old_age   Always       -       7646
  7 Seek_Error_Rate         0x000b   100   100   067    Pre-fail  Always       -       0
  8 Seek_Time_Performance   0x0005   128   128   020    Pre-fail  Offline      -       18
  9 Power_On_Hours          0x0012   096   096   000    Old_age   Always       -       33234
 10 Spin_Retry_Count        0x0013   100   100   060    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       3532
192 Power-Off_Retract_Count 0x0032   081   081   000    Old_age   Always       -       23343
193 Load_Cycle_Count        0x0012   081   081   000    Old_age   Always       -       23343
194 Temperature_Celsius     0x0002   130   130   000    Old_age   Always       -       46 (Min/Max 17/51)
199 UDMA_CRC_Error_Count    0x000a   200   200   000    Old_age   Always       -       530
ATA Error Count: 530 (device log contains only the most recent five errors)
Error 530 occurred at disk power-on lifetime: 32854 hours (1368 days + 22 hours)
  61 08 80 88 4d 48 40 08  20d+17:01:28.915  WRITE FPDMA QUEUED
  61 08 78 78 2e e9 40 08  20d+17:01:28.914  WRITE FPDMA QUEUED
  61 10 70 70 1f 75 40 08  20d+17:01:28.913  WRITE FPDMA QUEUED
  61 20 68 80 ec b3 40 08  20d+17:01:28.913  WRITE FPDMA QUEUED
  61 08 60 80 4d 48 40 08  20d+17:01:28.912  WRITE FPDMA QUEUED
Error 529 occurred at disk power-on lifetime: 32848 hours (1368 days + 16 hours)
  61 48 68 88 04 81 40 08  20d+11:09:09.066  WRITE FPDMA QUEUED
  61 10 60 50 ce 18 40 08  20d+11:09:09.065  WRITE FPDMA QUEUED
  61 08 58 48 ce 18 40 08  20d+11:09:09.065  WRITE FPDMA QUEUED
  61 08 50 40 ce 18 40 08  20d+11:09:09.065  WRITE FPDMA QUEUED
  61 58 48 e8 cd 18 40 08  20d+11:09:09.064  WRITE FPDMA QUEUED
Error 528 occurred at disk power-on lifetime: 32848 hours (1368 days + 16 hours)
  61 28 28 d0 58 a7 40 08  20d+11:02:42.300  WRITE FPDMA QUEUED
  61 20 20 20 29 45 40 08  20d+11:02:42.299  WRITE FPDMA QUEUED
  61 30 18 20 40 e4 40 08  20d+11:02:42.299  WRITE FPDMA QUEUED
  61 08 10 38 01 e5 40 08  20d+11:02:42.299  WRITE FPDMA QUEUED
  61 08 08 28 64 0f 40 08  20d+11:02:42.298  WRITE FPDMA QUEUED
Error 527 occurred at disk power-on lifetime: 32846 hours (1368 days + 14 hours)
  61 18 18 e8 37 79 40 08  20d+09:28:48.864  WRITE FPDMA QUEUED
  61 58 10 90 37 79 40 08  20d+09:28:48.863  WRITE FPDMA QUEUED
  61 08 08 80 0d 12 40 08  20d+09:28:48.863  WRITE FPDMA QUEUED
  61 10 00 70 0d 12 40 08  20d+09:28:48.863  WRITE FPDMA QUEUED
  61 08 f8 68 0d 12 40 08  20d+09:28:48.863  WRITE FPDMA QUEUED
Error 526 occurred at disk power-on lifetime: 32845 hours (1368 days + 13 hours)
  61 70 28 c0 44 ad 40 08  20d+07:53:52.412  WRITE FPDMA QUEUED
  61 10 20 d0 18 a7 40 08  20d+07:53:52.412  WRITE FPDMA QUEUED
  61 18 18 70 8f 43 40 08  20d+07:53:52.411  WRITE FPDMA QUEUED
  61 a8 10 78 ba e1 40 08  20d+07:53:52.411  WRITE FPDMA QUEUED
  61 10 08 b0 3a 72 40 08  20d+07:53:52.411  WRITE FPDMA QUEUED
# 1  Extended offline    Completed without error       00%     33228         -
# 2  Extended offline    Aborted by host               80%     32115         -
# 3  Short offline       Completed without error       00%     32111         -
# 4  Short offline       Completed without error       00%     32087         -
# 5  Short offline       Completed without error       00%     32063         -
# 6  Short offline       Completed without error       00%     32039         -
# 7  Short offline       Completed without error       00%     32015         -
# 8  Short offline       Completed without error       00%     31991         -
# 9  Short offline       Completed without error       00%     31967         -
#10  Extended offline    Completed without error       00%     31964         -
#11  Short offline       Completed without error       00%     31943         -
#12  Short offline       Completed without error       00%     31919         -
#13  Short offline       Completed without error       00%     31895         -
#14  Short offline       Completed without error       00%     31871         -
#15  Short offline       Completed without error       00%     31847         -
#16  Short offline       Completed without error       00%     31823         -
#17  Short offline       Completed without error       00%     31799         -
#18  Extended offline    Completed without error       00%     31796         -
#19  Short offline       Completed without error       00%     31775         -
#20  Short offline       Completed without error       00%     31751         -
#21  Short offline       Completed without error       00%     31727         -
I am not sure what to make of this. Drive 1 /dev/ada5 is less than 2 years old and has rarely seen usage.
Drive 2 /dev/ada5 are much older drives.
Insight and advise would be appreciated.
bigbrovar
I am attaching a screenshot for the srub result
(maybe) good news...
In both cases, your errors are CRC, so it could just be that you have issues with cabling or backplane. Start by checking that, zpool clear on the pool and see if the errors come back or not with another scrub.
samarium
is that the ICRC? 600 hrs ago?
bigbrovar
Thanks people. Cabling and Back-plane are my suspicion. I did notice the back-plane to be a bit loose and I would be ordering a new back-plane. Thanks so much guys.
I have ran a zpool clear and I would be reporting back if the issues comes up again.
