Netgear is pretty decent - full disclosure we're a Netgear Powershift Partner - but I've been quite happy with the Dell switching gear for a number of years and just recently upgraded our edge switches to Dell 7048P's.  Those replace some Dell 5324's which have been rock solid 1Gbps switches since like 2005.  We're not replacing them due to any problems with the 5324's ...  the 7048's just offer higher port density, power-over-ethernet, 4x 10G uplink, and L3 wirespeed routing capabilities, all of which are now relevant issues for us.
The 5324's are absolutely awesome full feature layer 2 switches that are now available used on eBay at a very modest cost.  They're fully managed, reliable, have a redundant power supply option, and basically you can get two of them (one as a spare) at a very attractive price.  They do have fans so are not totally silent.
I didn't check the 2724 to see how well (or even if) it supports LACP but the 5324 does so very well.  It's a slight learning curve to move up to a managed switch, but they're pleasant to use.
