Juvx
 - Aug 1, 2015
Yeah i just want it to work haha Ill worry about maxing later.We were talking about configuring the network...we never talked about tuning performance.
So right now my NAS is plugged into my router which is in a closet far far away from my office.. (thats where they decided to install my cable modem) I cant run cables and dont want to because i plan on moving in the next 6mo-1 year) so it would be a total waste of time and money.
I think my best solution is to move my NAS into my office and connect it directly to my workstation.. i know its not ideal but right now im looking for transfer speed above all else
Thank you ! that helps a lotWell, the steps to take to set up an IP address are covered in the respective documentation, so I won't go over those. Conceptually, though, you need to set up a different network. Suppose your router has an IP address of 192.168.1.1, and it's handing out IP addresses to the rest of your network. All your other devices are 192.168.1.x, where x is anything between 2 and 254.
When you set up the 10G NICs, you'll need to manually assign IP addresses, and they will need to not be in the 192.168.1.x range. For simplicity's sake set the IP address of the 10G NIC in your FreeNAS box to 192.168.2.1, and the one in your Windows box to 192.168.2.2. Both FreeNAS and Windows will allow other parameters to be entered when setting up those NICs; all but one are optional. You won't need to enter a default gateway, DNS server, or anything like that. You will need to enter a subnet mask, though. In Windows, that will probably be entered as 255.255.255.0. In FreeNAS, if you enter the IP address as 192.168.2.1/24, you'll be set.
When you connect to the share on the FreeNAS box from the Windows box, you'll then use that IP address--you'd connect to \\192.168.2.1\share.
It is? Productivity cost versus cable cost, what would weight more in your situation just depend on your need :)
Assuming you will continue using WiFi on your workstation for internet and a cable to connect to your FreeNAS. You might be with a configuration that you won't be able to connect to FreeNAS from the other PCs at your house, so back to cost?
The only other PC i have in the house is a Macbook pro.. im fine with not connecting it to the NAS for now.
I do also have an extra AC router that im not using, would it be possible to use it as a separate network (put it in my office) and not connect it to the internet?
Connect my PC and NAS to it wired and everything else wireless on a separate SSID if needed? Downside would be that my speed would be much lower using the 1gbe network to my main PC vs 10gbe.
Nope.do i need to reinstall freeNAS?
They're already there.or how do i install drivers for it?
They are compatible with FreeNAS. I assume they are with Win10 as well, though I admit I haven't touched Win10 yet.I hope the Chelsio S310E-CR 10Gb PCI-E are compatible.
Correct.I think ill test this out tonight over the exsisting 1gbe NICs first, I assume its the same exact process.
Thanks a lot you've been a big help.Nope.
Correct.
Is a crossover Ethernet cable required for the 1gbe NIC to NIC connection?Nope.
Correct.
hmm having problems connecting my pc nic to nas nic. i set windows ipNo, crossover cables are unnecessary with GbE.
It would probably be better than WiFi, but I still wouldn't expect anywhere close to line speeds.I wonder if a gigabit switch to power line adapter would help.
lack of Ethernet cables in my house
Looks like you'll be hard-wiring the house ... you know it makes sense.Hitting sustained 100-110 MB/s transfer speeds so now I know for sure my issue was probably my router
From what I've read recently, the newer powerline stuff is greatly improved over previous generations. You aren't going to get full GbE speed though. Could be worth looking into.I wonder if a gigabit switch to power line adapter would help.
I still cant. Just doesnt make sense, i plan on moving in 4-6 months. Looks like ill add the 10gbe direct connection i just got in the mail (2 NICs and wire) and just keep the NAS next to my desktop PC for now.Looks like you'll be hard-wiring the house ... you know it makes sense.
Right now im getting 50-60 mbps connection to the web on speedtest through powerline, so its not terrible. By wifi on my macbook easily does 400-500 mbps on speedtest through wifi when im close by.From what I've read recently, the newer powerline stuff is greatly improved over previous generations. You aren't going to get full GbE speed though. Could be worth looking into.
btw its Gb internet.
