ian351c
 - Oct 20, 2011
@SweetAndLow: Looks like as of 9.3 Linux jails have been deprecated in favor of Virtualbox. Not sure how I feel about that, since I never knew what I was missing, but there it is.
			Dat understatement.It's said that Linux jails were not very good in practice.
I'm not sure what you are talking about, I said I used a freeBSD jail to do the install, not a linux jail. Also there is still a crashplan plugin in 9.3. You can even do kldload linux.so in 9.3@SweetAndLow: Looks like as of 9.3 Linux jails have been deprecated in favor of Virtualbox. Not sure how I feel about that, since I never knew what I was missing, but there it is.
I'm trying this and getting nowhere. I'm in the UEFI shell, but when I type "fso:", it responds "Invalid mapping name - 'fso:'"I discovered that you can do all this via UEFI boot shell as documented here. There are a few differences though. So here is my recipe:
- Step 1 - Download version 16 of both the UEFI Flashing tool and the DOS/Windows Package containing the flash ROM image from LSI Support.
- Make sure it's v16 because that's the version of the driver FreeNAS 9.2/9.3 use and the firmware should match the driver.
 - Step 2 - Decompress them onto a USB Stick
 - Step 3 - Boot to UEFI shell on my SuperMicro motherboard
 - Step 4 - Navigate to the folder with the flashing tools and ROM like so:
- fso:
 - cd foldername
 - Step 5 - Erase and Flash the M-1015
- sas2flash.efi -o -e 7
 - sas2flash.efi -o -f 2118it.bin (Append -b mptsas2.rom if you want a boot ROM, but you don't need it)
 - Step 6 - Reboot and profit!
You can not flash IT firmware on the 9240-8i. If the plan is to use
the drives as JBOD, the 9240-8i supports JBOD.
You need to go into the WeBBIOS via CTRL+H keys. All new disks
should be detected as JBOD .If the drives are detected as Unconfigured
Good Drives, you can convert them into JBOD.
Use storcli to check for status
http://www.lsi.com/downloads/Public/RAID Controllers/RAID Controllers Common Files/1.13.06_StorCLI_u1.zip
storcli show
storcli /c0 show all
storcli help
storcli reference manual
http://www.lsi.com/downloads/Public/RAID Controllers/RAID Controllers Common Files/StorCLI_RefMan_revf.pdf
Thank you
It rebooted after the FreeNAS update, but I just rebooted again for good measure. Still no serials.A simple reboot has been useful in showing the serial numbers, IIRC.
