My server went down while I was out of town - where to troubleshoot?
eraser
How long does your system run before it hangs/crashes?
I'm wondering if you have a memory leak... Run "top" from the console and see if you are using any Swap space before the hangs happen. (You could also look at the WebGUI -> Reporting -> Memory section and view the "Swap Utilization" graph to see historical info)
hungarianhc
I just ran TOP, and it says 12GB total, 12GB free. But this is post-reboot so I'm not sure how to check pre-crash, other than w/ the WebUI.
Swap seems to stay completely constant, as seen in the attached screenshot.
