My own installation on Transmission
Jedrek
Hello
Please help me with my installation of the Transmission 3.0 for my own jail with FreeBSD 11.4. I don't use the internal plugin. I plan use the packages from FreeNAS 11.4 enviroment that i create my own jail. Very thanks for cooperations.
Redcoat
Jedrek
Thanks Redcoat, but I search another method of installation a Transmission. I was created my own jail with FreeBSD 11.4 enviroment. Now i need information about install Transmission with standard pkg's eg. transmission-web; transmission-cli etc.
Alecmascot
pkg install transmission-daemon
Jedrek
i was install it, but IP:9091 not working. The page is not available.
Alecmascot
Did you edit the white list ?
Alecmascot
Try here :
/var/db/transmission/settings.json
or google it.
Jedrek
this catalog
/var/db/transmission/ not exist, and file setting.json not exist. i will it, but i can't open www, error 403
Alecmascot
Google it: transmission daemon 403
