- May 28, 2011
Damn, I'm going against the grain here but with the costs dropping on the SSD's, I'd recommend finding the cheapest one you can buy if you have the available SATA port. The size of the SSD isn't important as long as it's 16GB or more. If the cheapest one is 120GB, that is fine, grab it. If you don't have a SATA port then both the SSD and DOM is out of the question and I wouldn't buy a DOM anyway, they cost too much. If you must go with a USB Flash Drive, buy a good one, I like the Sandisk Ultra Fit as well, I have a few of those but never used them for FreeNAS. Updates do take longer using a USB device but honestly, how frequently are updates done (LOL, not that frequent now but there are times when something new is released, lots of bug fixes mean lots up updates). I still use my USB Flash device but once my hard drives start to fail, I'm buying fewer larger capacity drives and opening up a SATA port for a boot device.
Also, mirrored boot devices, I'm not in favor of them in general because they do not work as intended because the main boot device has to fail in such a way that it doesn't hang the system and guess what, that is a rare situation, just do some searching in the forums. Make a backup of your configuration file after you make any changes to your system and you will be able to rebuild your system boot device without issue.
And just so every one knows, I do value Dr. KK's advice, he's a valuable source of information, just I don't always agree with everyone on everything.
