Chris Moore
- May 2, 2015
I am seriously considering buying a second chassis because I like it so much.Niiiiiiice! LOL, going to give backblaze a run for their money there, Chris?
Like I've said, the Noctua NH-D9L should fit. It's not really cheap, but the quality is great, especially the quality of the fan.
The best part of the Noctuas is the installation, very clean and easy. A child could do the installation without a problem.
I ordered the Noctua cooler. If I am lucky, it might be here in time for the weekend. I will update.I'll second the Noctua recommendation. Their selling point is that they are silent, but the only way they can be silent is because they do such a good job with the heat exchange.
Sitting mostly idle, right now, the average core temp is 40c. The screen capture I posted a few days ago was under load and it maxed out at 73c. It is within the thermal limit for the CPU, but I don't like it. I don't know if you looked at all the posts, but I just changed the CPU cooler to try to get less sound under load. The old one kept it cool but at the cost of undesired sound, this one is quiet but at the cost of undesired heat.However, I can't believe that your CPU is actually getting that hot if it's not under load.
I bet they would accept an offer of $350.
Wouldn't do me any good. Can't afford to fill it with disks!
Yeah, I saw that. That's why I was asking about the mounting angle. Some heatsinks are sensitive to orientation (their heat pipes align a certain way, and pretty much all CPUs have rectangular dies), and that was the first thought that popped into my head. I don't know anything about that particular heatsink, but it looks like it should do a better job than what it's doing.I don't know if you looked at all the posts, but I just changed the CPU cooler to try to get less sound under load.
Not all at once. Pace yourself. I only have 16 in mine right now. I am planning to do another pool of mirrored drives to use for iSCSI. It will take me a little time to get the drives together. It is a long term plan.Wouldn't do me any good. Can't afford to fill it with disks!
This is the second CPU cooler like this that I have used and the other one worked fine. I do have it oriented so the exhaust air blows toward the rear of the case, which is how it is intended to be used. It is really made for a 2U chassis and I am guessing it was designed to be just enough cooling to prevent the CPU from thermal throttling.I don't know anything about that particular heatsink, but it looks like it should do a better job than what it's doing.
I don't know, that works out to $922.75 ish per drive. I think I can find a better value, but I won't be needing that much storage any time soon. My plan was to create another pool for storing VMs and that will probably be smaller capacity drives in a pool of mirrors.I think I found the ultimate way to build those drives out. Pick up two of these and put backblaze out of business tonight. https://www.newegg.com/Product/Prod..._re=1tb_hard_drive-_-9SIAFCN6S84354-_-Product
I think 400TB worth of drives will have you sitting pretty.
+------+------------------+----+-----+-----+-----+-------+-------+--------+------+----------+------+-------+----+ |Device|Serial |Temp|Power|Start|Spin |ReAlloc|Current|Offline |Seek |Total |High |Command|Last| | |Number | |On |Stop |Retry|Sectors|Pending|Uncorrec|Errors|Seeks |Fly |Timeout|Test| | | | |Hours|Count|Count| |Sectors|Sectors | | |Writes|Count |Age | +------+------------------+----+-----+-----+-----+-------+-------+--------+------+----------+------+-------+----+ |da0 |Z4Z3xxxx | 29 |10726| 27| 0| 0| 0| 0| 1| 32350262| 1| 0| 0| |da1 |Z305xxxx | 28 | 3942| 11| 0| 0| 0| 0| 0| 19391749| 0| 0| 0| |da2 |Z305xxxx | 28 | 3957| 13| 0| 0| 0| 0| 0| 19954659| 0| 0| 0| |da3 |Z4Z3xxxx | 28 |10520| 27| 0| 0| 0| 0| 1| 30853325| 0| 0| 0| |da4 |Z4Z3xxxx | 28 |10518| 25| 0| 0| 0| 0| 0| 31348029| 2| 0| 0| |da5 |W4Z2xxxx | 28 |10522| 29| 0| 0| 0| 0| 0| 29942034| 3| 0| 0| |da6 |W4J1xxxx | 28 | 7486| 59| 0| 0| 0| 0| 0| 871291032| 0| 6| 0| |da7 |W4J1xxxx | 29 | 7486| 55| 0| 0| 0| 0| 0| 880695001| 0| 6| 0| |da8 |Z307xxxx | 28 | 4069| 42| 0| 0| 0| 0| 0| 15086013| 0| 0| 0| |da9 |Z307xxxx | 28 | 6647| 85| 0| 0| 0| 0| 0| 16963190| 0| 0| 0| |da10 |Z307xxxx | 27 | 6287| 44| 0| 0| 0| 0| 0| 16350404| 0| 0| 0| |da11 |Z307xxxx | 28 | 7568| 77| 0| 0| 0| 0| 0| 18977799| 0| 0| 0| |da12 |W4Z2xxxx | 28 |12703| 74| 0| 0| 0| 0| 0| 61060236| 1| 0| 0| |da13 |Z4Z2xxxx | 28 | 7071| 101| 0| 0| 0| 0| 0| 55613043| 3| 0| 0| |da14 |W4J1xxxx | 29 | 7486| 54| 0| 0| 0| 0| 0| 864333219| 0| 0| 0| |da15 |W4J1xxxx | 28 | 7461| 55| 0| 0| 0| 0| 0| 868276935| 0| 0| 0| |ada0 |PEPR3215005112xxxx| | 6471| 0| | 0| | | N/A| N/A| N/A| N/A| 0| |ada1 |NZ05T772xxxx | 35 |14665| 119| 0| 0| 0| 0| 0| 3825| N/A| N/A| 0| |ada2 |NZ05T772xxxx | 35 |14664| 124| 0| 0| 0| 0| 0| 2130| N/A| N/A| 0| +------+------------------+----+-----+-----+-----+-------+-------+--------+------+----------+------+-------+----+
Yeah, it was just hilarious that they are packaging twenty together.
Anyway, sold off the zCash and bought the case. Going to hopefully pick it up tomorrow. It's a lot cheaper than a hundred bucks to drive to OKC plus I will stop and have something to eat while I am down there. Otherwise it will have to wait till Tuesday when I am on my way through town.
Have to get a pair of coolers since I doubt my Hyper 212 Evo's will fit since I had to give a little space in the 4U I am using now. I imagine I will have to pick up SAS cables as well so be next month sometime before I get things done.
If anyone is looking to pick one up between OKC and Branson, MO let me know, I have to drive out there on the 15th and head back on the 16th so I can save you some cash on one of them as far as shipping goes.
This same seller has had these listed off and on all year (last year) and I imagine they would make a deal if you send them a message.Wow. With no shipping cost you got an insane deal. I mean, I'm kinda jealous. If they had another one available I would probably make them an offer but it looks like they only have a three pack left.
