My NAS project is feasible?
First of all, I would like to apologize for any errors in the text, because I'm using Google translator.
I am studying the viability to mount NAS servers to host VMWare virtual machines using ESXi 5.1 or 5:11.
The structure would probably be the following:
HOST 1 with VMWare ESXi 5.1 or 5.11 with 32 Gigabits of memory and 4 discs 1 T, with 1 quad-core processor with virtualization support (hardware DELL Power Edge T410).
1 HOST Intel FreeNAS 9.1.1 with 6 disc 1T with 1 Intel Xeon processor with virtualization support, 4 GB of memory.
The idea is to map the volumes zfs host FreeNAS on host VMWare via iscsi and create the VM's in these volumes (production environment).
I also thought of creating a VM ESXi on local disk, occupying almost the entire local disk, where it would fit another FreeNAS. This second NAS receive automatic replication of the volumes of the first NAS, thus creating a backup at scheduled.
This structure is suitable for server environment in companies? Is it safe?
I've done some tests and at first everything worked fine, but reading some forum posts I was afraid to use ESXi with FreeNAS (I may have misunderstood).
Remembering that I am beginner in the subject.
I thank all the possible collaborations.
hotalot
Virtualizar Freenas é completamente desconselhado, principalmente em ambientes comerciais. Eu iria de Openindiana substituindo o Freenas. No site Hardforum tem um tópico longuissimo sobre ZFS, Openindiana, OmniOs, etc. Boa diversão!
http://hardforum.com/showthread.php?t=1573272
Apologies to forum users about this post in Português.
Agradeço pela colaboração hotalot.
Neste caso, se não for abusar, colocaria ainda uma segunda situação. E se os dois servers NAS fossem hosts físicos, mapeados via ESXi utilizando isci?
Na verdade, o que quero é um meio de criar um storage de armazenamento das máquinas virtuais e, o mais importante, criar uma opção de backup das mesmas de forma automática e segura.
Obrigado!
hotalot
Fabiano, infelizmente a minha experiência com ESXI e virtualização em geral é mínima. Aconselho você a ler aquele tópico - vai levar muito tempo para absorver tudo ali - do hardforum. Também você tem a opção do NAS4FREE (que na minha humilde opinião dá de 10 a zero no Freenas), é muito mais rápido e melhor tem um forum em português para nosotros hehehe.
Links:
http://forums.nas4free.org/
Abraços e boa sorte.
hotalot
It would be nice! Thank you.
I don't know how much action it would get, on N4F Portuguese sub-forum there is little action, may be because the people in the know (developers, moderators, etc) don't speak portuguese.....
D
dlavigne
Guest
Let's give it a go. I'll create the sub-forum and move this post there as the first one.
Majik
Usando FreeNAS com esses parâmetros em um ambiente comercial ou empresarial seria fatal para a perda de dados. Você precisa de muito mais memória RAM para esta, além de ser uma máquina virtual pode causar muitos outros efeitos que serão enormes problemas para você, mais cedo ou mais tarde. Tenha cuidado com o meio ambiente NAS como a qualidade do equipamento pode torná-lo muito agradável ou um desastre. Olhe para as especificações no site do FreeNAS para mínimo e, em seguida, verifique se você tem isso ou mais.
Boa sorte com a sua construção!
joeschmuck
Old Man
The other option for languages not English based would be for those other people to translate using an online translation tool. It doesn't always work great but at times I do that to help out someone in other forums. Also they are bound to get a faster response. But I think it's a good ideal to open up other languages in the sub-forums.
Majik
I agree totally. These guys trying to translate technical stuff on Google translator will be interesting for sure........;)
