Hi, this is the problem I's trying to resolve.
Recently, after a weekend, I received the following alerts
Uh-oh...
This is a basic system, which I set up in 2013, with an MSI motherboard, i3 CPU and 2x8GB of non-ECC RAM.
(It hasn't had much use on a daily basis and most of the stuff just lives there. All has gone well up to now, maybe I've just been lucky to date)
Don't think disks are encrypted and Dedup is not enabled.
On reboot, bios reported RAM had changed, memtest revealed a defective stick of RAM.
Replaced RAM.
and
HomeStor1 is a mirrored array of 2 disks
HomeStor2 is a striped mirrored array of 2x2 disks
HomeStor 3 is a single disk (might even be NTFS import) and is only used for temporary storage of large avi files when being edited (complements second drive on main PC)
I was able to import HomeStor3 (and it's dataset) successfully. As it's contents are not important I though this was the best one to try first.
HomeStor1 is docs and photos which are much more important and is backed up to another off-the-shelf NAS, most recent backup was about 2 weeks before the crash.
HomeStor2 is Rips of 400 DVDs and BluRays, many of which I could do again but it would take ages.
I set this box up back in 2013 as a NAS for my home to share files between (windows) PCs and provide some protection against data loss and I have periodically replaced disks and boot drives without problems.
I've had a look around the forums but I am unsure how to proceed.
I cannot remember what I named the various shares, users accounts, etc etc. Maybe this is not important, and maybe it is.
I have both a tar and db file of the config (although tar is definitely causing crashes)
Also have original Flashdrive with Freenas on it.
Just remembered, this original flashdrive reported it was full, about 6 weeks ago, and I removed a number of older versions of freenas using the GUI.
Apologies for the length but wanted to post as much information as possible.
Any suggestions greatly appreciated.
J
Uh-oh...
Replaced RAM.
- I tried rebooting, boot device is a usb3 flashdrive, got nothing but a bootloop.
 - I downloaded and installed Freenas 11.3 onto a usb2 flashdrive I had spare. Booted okay, but when I uploaded config file, I got another bootloop.
 - Tried again without uploading config file, shell'd, and <zpool import> yielded the following
and
J
