Hi guys,
I’m reusing my old mobo Asus P5K-E for my freenas file storage. It’s been working fine except every time it reboots I have to take 1 Hdd out and wait for booting progress then reinsert that hdd in (because the boot drive can only be recognized in bios when using 11drives). My case supermicro 846 EL has 24 slots but so far I can only use 12 due to this limitation. Is there anyway I can solve this issue? Is there a way to make it boot when using >11hdds? Must I upgrade? I have a supermicro X9DAI-o with dual Xeon 2560 V2 & 64GB to be used for Freenas but only if I must upgrade. Is this configuration any good? My hdd controller is Adaptec 24 ports use as JBOD pass through (I know LSI HBA is better but I try to reuse as much as I can). Please advise. Thank you all.
My current configuration:
- Mobo: Asus P5K-E bios 2.58
- CPU: intel core 2 Quad Q6600 2.4GHz
- RAM: 8153MB (maxed out
I know it’s freenas minimum...)
- Hdd controller: ARC-1880 24hdd
- Case: supermicro 846EL
- Freenas 11.1 - U5
- PSU: Supermicro 1200W
- Freenas 11.1 - U5
