MadManChris1
- May 2, 2014
Hey so I'm new to this forum, I had a quick look over some of the pinned stuff and it was very helpful.
I've finalised my nas build and I am going to buy it tonight.
I have messed around with Freenas in an old pc but its time to take it to the next level now.
Here's the components:
Case: Fractal Node 304
Mobo:C2550D4I - ASROCK MOTHERBOARD MINI-ITX C2550 FCBGA1283 SOCKET
Ram: Kingston Technology KVR16E11/8 8GB DDR3 1600Mhz ECC DIMM Memory with Thermal Sensor (unbuffered)
PSU: Seasonic SS-250SU 250W Flex ATX 1U power supply
HDD's: 2 x 3TB WD reds. I am going to expand to 6 drives when I have the money and will start the pool from scratch again. Raid 1 config for the two drives until I expand.
I only have one concern and that is about the Ram it ticks all of asrocks specifications so in theory it should work. Can anyone confirm it does or at least that it should?
I plan to use Plex media centre and maybe a few other plugins. I will use a ZFS.
I'm really excited about this new project, and will probably be spending more time on these forums.
How does this build sound to you guys? let me know if you need more info.
Thanks in advanced.
Thanks in advanced.
