I have been reading these forums for awhile now learning all about zfs and have decided to finally move forward. This build proposal is going to sound a bit crazy and mismatched, but it is only because I am trying to reuse server parts I got on the cheap. A friend sold me his Intel 3rd gen Ice Lake (8360) for super cheap along with some ddr4 ecc memory so I am trying to figure out how to use it. It seems overkill for a nas build but would the following work? Black Friday is coming up so I hope to buy six (18tb to 22tb) drives depending on sales. I found a Tyan server motherboard with IPMI that can run this processor for only $300.  Originally these were $900 boards but it is for a 2 year old processor.
My use case is primarily as a plex server and to store pics/videos that are personal. I want a ton of storage and plan to backup to external usb drives occasionally as well as my most important stuff online and encrypted. I don't expect the system to get a ton of heavy usage so the storage performance isn't as important as data redundancy so I don't have to deal with trying to restore from backups. I plan to add up to four 4k cameras to record h.265 compressed videos to the storage as some point next year. I also plan to add a GPU to do AI video object detection on my cameras, but initially I won't have that. Unfortunately, in my house I only have 1Gbit networking. The house has 20 year old cat5 cables, so it is lucky I can even get Gbit. This somewhat complicates how I will do video recording and networking so that I am not congesting my network for everything. I have some ideas on how to redo the networking that I will deal with in the future. I know this system is way over powered for my use case, but if I can do AI object detection using just CPU cores on a smaller video that might make it so I don't ever even need a GPU.
Case: Fractal Design R4 -- This is my case from 12 years ago but other than a few dents is good enough. I am going to add another fan to the back of the case to pull air through better.
Board: TYAN S5642AGM3NRE-2T SSI CEB Server Motherboard LGA 4189 Intel C621A I checked forums online and measured and think this will fit my case. It has a dedicated mgmt port.
Power Supply: 1200w EVGA -- A bit of overkill but I already have it from another build I did not finish.
CPU: Intel Ice Lake (8360)
CPU fan: Not sure but I'll get something that fits the 4189 socket. I couldn't find a water cooling solution for this.
GPU: Nothing for now but hope to add something in the future.
Memory: 128GB ddr4 ECC
Drives: TBD but I am initially planning 6 x 20tb in a raidz2 setup.
Cables: Pretty sure I will need two of the mini SAS to 4 Sata cables.
Software Setup
I plan to use Truenas Scale. I plan to start with my 6 drive array as a raidz2 in just one vdev. If I ever need more storage I hope that the raidz expansion is fully integrated and working. At that point I will just add another disk or two and expand the vdev. That probably won't happen for 3 years or so. If a drive ever goes bad, I will just buy a new one online and replace hoping that 2 more drives don't fail in the meantime.
The one big open I have is the boot drive and some of the more advanced zfs setups. I have a 600GB SSD I will use for that. I've not really researched this part yet to see if there is anything I really need to do. I saw some people will use a drive as a cache for ZFS. That part is a little fuzzy to me that I think I can figure out once I start setting everything up.
Is there anything I am missing in this? I've never build a NAS storage server. I think this setup is going to cost me less than a similar Qnap/Synology enclosure with 6 bays but with way more performance, expansion capability, and of course power consumption will be higher as well as the overall system bigger and noisier.
Software Setup
