sschwetz
 - May 25, 2020
After a reboot of my  system the GUI shows that 3 drives are unassigned on Storage > Disks. However, these drives are one of the paths of separate multi-path disks. If I go to Storage > Multi-path the drives show that they are part of 3 paths of the correct multi-path disk.
System is running as a ESXi Guest with:
Nothing has changed on the system, and it has been stable. Scrubs show no issues. Performance is as expected
So 2 part question:
- 250GB RAM
 - 6x vCPU
 - 2x HP 240 series HBA flashed to LSI P20
 - 5x HP 2700 SFF Chassis each with 25 Disks
 - 3 x chassis daisy chained with 1 path into each HBA
 - 2 x chassis daisy chained with 1 path into each HBA
 - HBAs are PCI Passthrough to the VM
 - 4 Chassis have 25 600GB SAS 10K drives
 - 1 Chassis has 20 600GB SAS 10K drives and 2x intel 3700 200GB SATA SLOG and 3x Intel 3700 200GB SATA L2ARC
 - System has been shut down and all paths have been confirmed as going to the correct ports
So 2 part question:
- Has anyone come across this before; and
 - Is their a way to make sure that multi-pathing is working correctly and if it is to remove the drives showing as available in the GUI?
