mount failed
Sepa
today my server froze and when rebooted i got the segmentation fault (pid 82 (sqlite3), uid 0: exited on signal 11). then the standard /bin/sh on /etc/rc termionated abnormally
NSSWITCH(_nsdispatch): files, passwd_compat, endpwent, not found, and no fallback provided
Any ideas what is it about? smells like a bad hard drive, but fsck can't find any problems...
thanks in advance :)
DrKK
FreeNAS Generalissimo
Sir, are you even using FreeNAS? There is no fsck for the ZFS filesystem.
Sepa
Yes, you are right. But during boot it does fsck and reports system clean.
Anyway, today it just started working again, for no special reason...
rogerh
Without any further info, my only comment is: make sure you have good, working backups.
DrKK
