Motherboard Swap???
Baldrick
I was wondering if I could save my configuration, swap out motherboards, and then reinstall the config file without problem? My disks are not changing.
Or, do I need to reconfigure from scratch?
Thanks!
FreeNAS is not hardware locked like Windows is. You can replace the motherboard, CPU, just about everything and use the same USB stick and disks to have a working system. ;)
