monthly run output how to enable?
sy5tem
i received an email saying this...
Doing login accounting:
total 0.00
Posting monthly OS statistics disabled
set monthly_statistics_enable="YES" in /etc/periodic.conf
-- End of monthly output --
i really need to edit /etc/periodic.conf ? is that not gone on upgrade after? is there another way to enablke the monthly output?
thank you
Fig Newton
I have been receiving these too. I have tried a few things but have been unsuccessful.
Did you ever figure it out?
Thanks.
fracai
It's not telling you there's a problem. It's letting you know what you would change if you want your stats to be uploaded to the FreeBSD site.
Brand
Now thats funny. People trying to change settings without even having a clue of what they are.
nello
Please don't laugh or flame: How does one edit this /etc/periodic.conf ? Is it possible to use a GUI text editor?
D
dlavigne
Guest
One could use the vi text editor in Shell, but the changes would be overwritten after a reboot or upgrade. If this feature is important to you, create a feature request at bugs.freenas.org asking for either the monthly be enabled or the ability to edit periodic.conf be added to the GUI.
nello
