Sightblinder
- Jul 17, 2012
Hey!
I have enabled proftpd and it works just fine. What I miss though, or at least can't find, is a way through a GUI monitor/controll who (what connection) is connected to the FTP and what they are doing. I have googled around but have not found any solution to it. I did find phpftpwho that apparently does what I am looking for, to an extent, but I don't know if it will work with FreeNAS-8.2.0-RELEASE-p1-x64 that I run or how best to install it. Does anyone know if it is possible and how to go about to do it? Or if there is any other plugin or packages that can be installed other than phpftpwho?
Thank you in advance for any tip or advice you have.
