RedMercury
 - May 12, 2023
I have just installed TrueNAS-SCALE-22.12.2 on a new machine.  I have a brand new QNAP enclosure (QNAP TR-004U) configured in individual disk mode with brand new 6TB SATA drives installed.  The enclosure is connected to the TrueNAS machine using USB3.
When I go to create a new pool using the new disks, only one disk appears, and the rest do not. The disk is the size of the individual HDD and I've double checked that the enclosure is configured in individual disk mode.
dmesg log confirms that the individual disks are known to the kernel:
Thanks!
Any ideas why this would be the case and how I can fix it? I've attempted to manually install a new GPT on each drive from the shell, but that didn't fix things.[ 3.929666] sd 3:0:0:0: [sdb] Very big device. Trying to use READ CAPACITY(16).
[ 3.929933] sd 3:0:0:1: [sdc] Very big device. Trying to use READ CAPACITY(16).
[ 3.930052] sd 3:0:0:0: [sdb] 11721045168 512-byte logical blocks: (6.00 TB/5.46 TiB)
[ 3.930057] sd 3:0:0:0: [sdb] 4096-byte physical blocks
[ 3.930204] sd 3:0:0:1: [sdc] 11721045168 512-byte logical blocks: (6.00 TB/5.46 TiB)
[ 3.930208] sd 3:0:0:1: [sdc] 4096-byte physical blocks
[ 3.930491] sd 3:0:0:0: [sdb] Write Protect is off
[ 3.930493] sd 3:0:0:0: [sdb] Mode Sense: 47 00 00 08
[ 3.930792] sd 3:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.931150] sd 3:0:0:1: [sdc] Write Protect is off
[ 3.931153] sd 3:0:0:1: [sdc] Mode Sense: 47 00 00 08
[ 3.931327] sd 3:0:0:2: [sdd] Very big device. Trying to use READ CAPACITY(16).
[ 3.931448] sd 3:0:0:2: [sdd] 11721045168 512-byte logical blocks: (6.00 TB/5.46 TiB)
[ 3.931450] sd 3:0:0:2: [sdd] 4096-byte physical blocks
[ 3.931738] sd 3:0:0:2: [sdd] Write Protect is off
[ 3.931740] sd 3:0:0:2: [sdd] Mode Sense: 47 00 00 08
[ 3.932027] sd 3:0:0:2: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.933057] sd 3:0:0:3: [sde] Very big device. Trying to use READ CAPACITY(16).
[ 3.933346] sd 3:0:0:1: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.935224] sd 3:0:0:3: [sde] 11721045168 512-byte logical blocks: (6.00 TB/5.46 TiB)
[ 3.935228] sd 3:0:0:3: [sde] 4096-byte physical blocks
[ 3.935518] sd 3:0:0:3: [sde] Write Protect is off
[ 3.935520] sd 3:0:0:3: [sde] Mode Sense: 47 00 00 08
[ 3.935807] sd 3:0:0:3: [sde] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.943207] sdd:
[ 3.944326] sd 3:0:0:2: [sdd] Attached SCSI disk
[ 3.944764] sdb:
[ 3.946318] sd 3:0:0:0: [sdb] Attached SCSI disk
[ 3.947606] sdc:
[ 3.947859] sde:
[ 3.948886] sd 3:0:0:1: [sdc] Attached SCSI disk
[ 3.950032] sd 3:0:0:3: [sde] Attached SCSI disk
[ 5.386077] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 5.515423] sd 2:0:0:0: Attached scsi generic sg0 type 0
[ 5.515486] sd 3:0:0:0: Attached scsi generic sg1 type 0
[ 5.515528] sd 3:0:0:1: Attached scsi generic sg2 type 0
[ 5.515582] sd 3:0:0:2: Attached scsi generic sg3 type 0
[ 5.515642] sd 3:0:0:3: Attached scsi generic sg4 type 0
Thanks!
