I wanted to install freenas on an old box for a friend of mine to have his own nas at home. Nothing funky just 500Gb hd.
I was however checking the minimum hw spec required (http://doc.freenas.org/index.php/Hardware_Requirements) by freenas. I know freenas 8 does many things but can I say that the RAM requirement is enormous?
I'm planning to use UFS and CIFS only... do I really need 4Gb of ram just to install it?
I seem to remember freens 7 needed 256Mb for a basic installation.
Is there any way to install freenas 8 on a box with 512Mb of ram?
If not I think I'd better install freenas 7 but that's not supported any more (AFAIK) or as a very last option install a basic Linux distro and samba...
Any input?
thanks
Any input?
thanks
