SOLVED 'min_memory' error on running VM after upgrading to 22.02.4
GS059
I finally figured out how to get my system to update from 22.02 to 22.02.4.
now I am unable to run any VM, existing or newly created ones. I did try searching this forum and quite a bit of google, not saying I am great at search though.
I have 128GB of ram, Virtualization tab shows I have 106 GiB free, VM only wants 8 of these GiB's. I did try reducing the VM down to 1GiB to see if that would help.
This is the point where it seems to error out.
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_memory_info.py", line 133, in get_vm_memory_info
vm_min_memory = vm['min_memory'] * 1024 * 1024 if vm['min_memory'] else None KeyError: 'min_memory'
NugentS
22.02.4 doesn't exist
GS059
then what am I on?
morganL
Captain Morgan
Administrator
then what am I on?
That's a nightly image?.. this can have bugs. Where did you get it?
The release version is 22.02.3
I think you should re-install or roll back.
GS059
I was on the nightly a while back since the PCIE passthrough wasn't working on the stable version. my system said it had an update, and after modifying the .py file to finally get it to allow for updates, this is the version it grabbed.
morganL
Captain Morgan
Administrator
Make sense. Nightlies are less stable... and have not gone through a QA cycle for any changes made.
Can you manually move to SCALE 22.02.3 and then confirm if the issue exists.
GS059
issue resolved by installing the release version from .iso.
it also does look like the PCIE passthrough works on this version as well.
