JDCynical
- Aug 18, 2014
System has a BCM57810 based 10g card, core works with it fine. Booted the scale ISO, and received:
'[bnx2x_func_hw_init]Error loading firmware
[bnx2x_nic_load] HW init failed, aborting'
I know the card needs external FW to work under Linux, however,
Normally, I'd put a copy of the non-free FW deb on the pool to install it after the installer is done, but I found this post on the forum with someone saying the non-free FW package is getting wiped with each nightly update.
Is this something that is still happening, the FW install getting removed with updates? I know the BNX cards are known to be twitchy, but with the card working nicely in the year+ I've had it in service, I'd like give it a chance under scale before looking for a ConnectX-3 or similar (sunk cost fallacy? perhaps).
find / -name *.fw doesn't find any firmware on the ISO.Normally, I'd put a copy of the non-free FW deb on the pool to install it after the installer is done, but I found this post on the forum with someone saying the non-free FW package is getting wiped with each nightly update.
