Purplebogan
- Dec 2, 2022
Hi all,
After upgrading my TrueNAS Core server (latest release version) to TrueNAS Scale (latest release version), it has been doing nothing but constantly kernel panicing and then not responding.
Here is a typical screen shot of a panic after attaching a monitor to it.
imgur.com
The hardware is an HP N54L Microserver with 16GB of ram, I have owned it since it was new.
The whole time I have had FreeNAS/TrueNAS core on it and it has NEVER had a single kernel panic or any failure.
The OS runs on a crucial SSD and worked perfect on TrueNAS core/freebsd.
In trying to get the linux based trueNAS Scale more stable I upgraded the ZFS pools to the latest version, that didn't help at all.
I only upgraded to Scale because I wanted to try Home Assistant which became only available in Scale.
I have decided I dont need Home Assistant and would much rather just be on TrueNAS Core and not get any more kernel panics etc.
So my biggest question is can I reinstall a fresh latest TrueNAS Core and will my ZFS pools upgraded via the latest version of Scale be compatible with Core or is Core behind in anyway in that regard?
If there is a more stable version of the TrueNAS Scale kernel available then I would be happy to use it, I don't care if its last generation or a super slow version that runs everything at half the speed...
imgur.com
Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users.
