terry5008
- Sep 16, 2023
I've noticed that the TrueNAS-CORE doc hub gives instructions on SSD over-provisioning(OP) of a SLOG via System > Advanced > Storage, but does not cover a solution for SSD OP of a Metadata vdev. My questions are as follows:
- Is there a way to OP Metadata SSDs even if it means using CLI or OS shell commands?
- Am I making this too complicated? Should I instead just do the OP SLOG and set all writes to sync writes?
- If I do the OP SLOG, how do I verify that it IS in fact doing what I configured it to do? Does the setting in System > Advanced > Storage cause a SLOG partition to be created of the stated setting size that can be viewed with another tool?
