mdnsd AirPrint
kai80
I switched from Ubuntu Linux to freeNAS on my home server. On my old setup I configured cups to announce AirPrint using Avahi. That worked fine as all my iOS devices found the announced printer.
Now with freeNAS (latest version) I created a jail, installed cups and configured it according to http://superuser.com/questions/673880/airprint-and-airplay-on-freenas.
However, the latest freeNAS does no longer use Avahi, but mdns. Therefore the generated AirPrint Avahi service isn't used. My Mac finds the printer using Bonjour (mdnsd is started within the jail), but iOS doesn't. So my question is: How can I configure mdnsd to announce my printer as AirPrint compatible?
Middling
You can use Avahi from inside the jail.
IIRC by default it comes with dbus enabled so you need to switch if off in (your jails's) /usr/local/etc/avahi/avahi-daemon.conf
Search for a line
[server]
enable-dbus=yes
and switch it to "no" (or add that line if it's not present).
Then edit your jail's /etc/rc.conf and add
avahi_daemon_enable="YES"
Restart Avahi with
service avahi-daemon restart
and you should be good to go.
I don't have any iOS devices but have previously checked my CUPS jail is working in my brother's iPhone.
kai80
Search for a line
[server]
enable-dbus=yes
Restart Avahi with
Thanks for your answer! When I try to install Avahi, pkg wants to uninstall cups (guess mDNSResponder is a dependency of cups?):
# pkg install avahi
Updating repository catalogue
FreeBSD repository is up-to-date
All repositories are up-to-date
Checking integrity... done (1 conflicting)
Checking integrity... done (0 conflicting)
The following 10 packages will be affected (of 0 checked):
Installed packages to be REMOVED:
    cups-base-1.7.3_1
    cups-1.7.3
    mDNSResponder-544_2
New packages to be INSTALLED:
    avahi: 0.6.31
    avahi-libdns: 0.6.31_1
    avahi-gtk: 0.6.31_2
    avahi-header: 0.6.31
    libglade2: 2.6.4_7
    xmlcatmgr: 2.2
    avahi-autoipd: 0.6.31
The operation will free 13 MB
Proceed with this action [y/N]:
I'm new to freeBSD. How can I install both, Avahi and cups?
Middling
It's been several months since i did this but i don't think i used pkg. I'm fairly sure i built CUPS using the ports system and i think i did a "make config" prior to building and switched it back to using Avahi.
kai80
Yes, that fixed it. Thanks a lot!
