Can't seem to get the 2 white 6GB/s ports working without it showing an error. I've tried a new cable, swapping out the backplane. It does show 10 drives in the view discs option but the console has the below error.
It seems to work if i put the last 2 drives in the 3 gb/s ports? Do i need to change something for it to work. The last 2 drives are the new drives.
Will i be OK if use the 3gb/s ports if the other 8 are connected to the lsi controller (6gb/s)?
Edit: I've just tried it with normal sata cables and sata power to connect to ports 1 and 2 and there is no error and works fine... I've tried swapping out the backplane and backplane cable and still get the error. The problem can't be the backpane or the cable though if it works on the 3gb/s ?
I have removed the cable from the first white port and it works, so i think it's something to do with the first white port? but it works on normal sata / sata power?
edit 2: in the bios the port 0 drive doesn't show if its connected to any of my backplanes but it'll work if i connect normal sata power and sata cable?
Any idea what the problem can be and how to fix?
