Hey, I've been using my new NAS for about a month or so and I've been fairly satisfied so far.
However while sabnzbd is repairing/unpacking completed downloads i'm unable to
"smoothly" use the pool. If i try and stream something to my OPPO 103 using SAMBA
i get stutters and the content is un-playble.
If i try and use windows explorer it is lagging massively, (i just try browsing directories).
Also after the repair/unpack process has finished i can still hear the drive preforming
what i assume is the last "write" functions from the sabnzbd file, (the drive is "ticking").
Generally the array seems busy for quite some time after sabnzbd reports the unpacking as "finished".
I run a Xeon E3-1230v3 with 16gb on x10sll-f board and 6X3TB RaidZ2.
Should i add more ram? install a l2arc? replace sabnzbd with nzbget? switch to NFS?
Thanks!
Thanks!
