Low Profile LSI M1015 - Mini SAS to SATA - 2U Chassis
Soljia
I'm sure the title is sufficient, however, I will explain. I have a 2U chassis, and a Low Profile LSI M1015. I bought 2 mini sas 90 host to sata cables, however, the 90 doesn't fit over the notch in the card. I've tried looking up online with anyone in the same situation, and I found a few unresolved threads. Is there any cable out there that would work? I see that there are Reverse 90 mini sas to mini sas cables, but not a breakout one. Any ideas, or am I doomed to get a different card or larger chassis? I guess I could swap the backplane, if even possible..
Thanks!
Link - This is my case.
http://www.supermicro.com/products/chassis/2U/822/SC822T-400LP.cfm
I also bought 90 degree SAS breakout cables, and they didn't fit. I ended up with regular straight connectors, and they work fine.
Soljia
Can a straight make a semi-sharp 90(aka around the card in between the card and chassis lid)? I tried looking up bend radius. I'm assuming it can.
Soljia
Can you let me know what cable you are using? I'm thinking of using monoprice, but I know some cables are more flexible than others. Thanks again.
Z300M
When using the Monoprice cables with which I started I kept getting errors, so I replaced them with cables (unknown brand) that I think came from SuperBiiz. However, I did disconnect and reconnect all the power connectors at the same time, so I can't be sure that the Monoprice cables were the problem.
I bought these cables from Amazon.
Z300M
jgreco
Resident Grinch
The M1015 is a poor choice in a 2U chassis. We've been using the Dell card, which is trickier to flash but is inexpensive. You can also use the retail LSI HBA. Both the Dell and LSI cards do not have the vertical space issue that the M1015 does.
Soljia
Ya, figured that out the hard way. If this doesn't pan out I'll just put the card up for sale and flash it to whatever version someone wants. Do you have a preference between the Dell card or LSI HBA?
jgreco
Resident Grinch
If money's not a big thing, the LSI card is easily flashed and has a well-engineered feel to it. The Dell feels ... Dellish? But at half the cost, ...
