sunshine931
 - Jan 23, 2018
I'm re-building my pool, and am looking for suggestions around vdev design.
I've got 24x HGST 3TB SAS6 drives to work with for my data vdevs, installed in NetApp DS4246 attached to a SAS6 HBA (not RAID controller).
Does anyone have a suggestion for other vdev layouts?
My use-case is a blend of:
- VMs via iSCSI, mostly lab workloads (lab as in playing with stuff, not scientific laboratory data)
 - Home-users using SMB/CIFS shares via gigabit ethernet
 - Plex media server VMs accessing the data via NFS, multiple Plex users in the home via gigabit ethernet, and external users at no more than 20mbps
- 12x mirrored pair vdevs (2 drives each vdev, 1/2 "wasted")
 - 8x raidz1 (3 drives each vdev, 1/3 "wasted")
 - 2x raidz2 (12 drives each vdev, 2/12 "wasted")
- the 12x mirrored pairs will perform best, but it's a wasteful layout
 - the 8x raidz1 would be a good compromise between performance and waste
 - the 2x raidz2 would be very resilient to outage and the least wasteful, but less performant than the other options
- System has 64GB ECC RAM
 - I have SSD available to use as cache, but need to assess the read performance vs. the data vdevs first
 - I will very likely be adding slog to address sync-writes from the VMs, but again, will want to do some testing
