It is more complicated that you think. Here are some of the gotchas;
- You have to check if the backup server is already powered on.
- After sending the power on command, (either WOL or IPMI), you have to wait until server is both booted and all the services are available
- A check if the backup script is already running, (it could be taking days or weeks for unknown reasons).
- You would have to check the network connection speed. If the backup server is used rarely, a wire or pin may fail in the cable route, thus ending up with 10/100Mega-bits per second instead of Gigabit speeds. (Assuming you are using copper 10/100/1000Mbps Ethernet.) If you don't check, you could find backups running forever and not know why.
- Another script, or pre/post task would be needed to see if your backup server needs to run a scrub or SMART tests. If so, run those tests.
In essence, you have to manually manage a few things that a primary / always on NAS server does for you.
I was reminded of this because I am updating my old laptop, (it uses ZFS for both OS and other storage). Before the update, I made sure the 2 pool scrubs finished so that the disk I/O was not going to slow down the update. (I only update this laptop about once a month, so each time it needs to run a scrub.)
