Thanks Simone for your reply.
Please note two major errors:
1) portmaster
portmaster audio/logitechmediaserver
===>>> The value of PORTSDIR cannot be empty
===>>> Aborting update
2) initial install does not seem to report version informaton
What do you want to do?
1. Install Logitech Media Server
2. Uninstall Logitech Media Server
3. Check for updates
4. Exit
3
===> Checking installer updates ...
It seems that the version file is missing or corrupted; downloading the latestversion...
override rwxr-xr-x root/wheel uarch for /usr/local/bin/lms_installer? y
rm: /usr/local/etc/lms_installer/installer_version: No such file or directory
===>Updated successfully!<===
Restart lms_installer please!
Entire Install log
FreeBSD 13.1-RELEASE-p7 n245418-79e75956dbb TRUENAS
Welcome to FreeBSD!
Release Notes, Errata:
https://www.FreeBSD.org/releases/
Security Advisories:
https://www.FreeBSD.org/security/
FreeBSD Handbook:
https://www.FreeBSD.org/handbook/
FreeBSD FAQ:
https://www.FreeBSD.org/faq/
Questions List:
https://lists.FreeBSD.org/mailman/listinfo/freebsd-questions/
FreeBSD Forums:
https://forums.FreeBSD.org/
Documents installed with the system are in the /usr/local/share/doc/freebsd/
directory, or can be installed later with: pkg install en-freebsd-doc
For other languages, replace "en" with a language code like de or fr.
Show the version of FreeBSD installed: freebsd-version ; uname -a
Please include that output and any error messages when posting questions.
Introduction to manual pages: man man
FreeBSD directory layout: man hier
To change this login announcement, see motd(5).
root@LMS:~ # pkg install curl
The package management tool is not yet installed on your system.
Do you want to fetch and install it now? [y/N]: y
Bootstrapping pkg from pkg+
http://pkg.FreeBSD.org/FreeBSD:13:amd64/quarterly, please wait...
Verifying signature with trusted certificate pkg.freebsd.org.2013102301... done
[LMS] Installing pkg-1.19.0...
[LMS] Extracting pkg-1.19.0: 100%
Updating FreeBSD repository catalogue...
[LMS] Fetching meta.conf: 100% 163 B 0.2kB/s 00:01
[LMS] Fetching packagesite.pkg: 100% 6 MiB 1.7MB/s 00:04
Processing entries: 100%
FreeBSD repository update completed. 32415 packages processed.
All repositories are up to date.
Updating database digests format: 100%
The following 9 package(s) will be affected (of 0 checked):
New packages to be INSTALLED:
ca_root_nss: 3.86
curl: 7.88.1
gettext-runtime: 0.21.1
indexinfo: 0.3.1
libidn2: 2.3.4
libnghttp2: 1.48.0
libpsl: 0.21.1_6
libssh2: 1.10.0_1,3
libunistring: 1.1
Number of packages to be installed: 9
The process will require 11 MiB more space.
3 MiB to be downloaded.
Proceed with this action? [y/N]: y
[LMS] [1/9] Fetching indexinfo-0.3.1.pkg: 100% 6 KiB 5.7kB/s 00:01
[LMS] [2/9] Fetching libnghttp2-1.48.0.pkg: 100% 128 KiB 130.7kB/s 00:01
[LMS] [3/9] Fetching libidn2-2.3.4.pkg: 100% 134 KiB 137.1kB/s 00:01
[LMS] [4/9] Fetching libunistring-1.1.pkg: 100% 555 KiB 568.6kB/s 00:01
[LMS] [5/9] Fetching libssh2-1.10.0_1,3.pkg: 100% 248 KiB 254.4kB/s 00:01
[LMS] [6/9] Fetching libpsl-0.21.1_6.pkg: 100% 63 KiB 64.2kB/s 00:01
[LMS] [7/9] Fetching curl-7.88.1.pkg: 100% 1 MiB 1.5MB/s 00:01
[LMS] [8/9] Fetching gettext-runtime-0.21.1.pkg: 100% 166 KiB 170.3kB/s 00:01
[LMS] [9/9] Fetching ca_root_nss-3.86.pkg: 100% 267 KiB 273.0kB/s 00:01
Checking integrity... done (0 conflicting)
[LMS] [1/9] Installing indexinfo-0.3.1...
[LMS] [1/9] Extracting indexinfo-0.3.1: 100%
[LMS] [2/9] Installing libunistring-1.1...
[LMS] [2/9] Extracting libunistring-1.1: 100%
[LMS] [3/9] Installing libidn2-2.3.4...
[LMS] [3/9] Extracting libidn2-2.3.4: 100%
[LMS] [4/9] Installing gettext-runtime-0.21.1...
[LMS] [4/9] Extracting gettext-runtime-0.21.1: 100%
[LMS] [5/9] Installing libnghttp2-1.48.0...
[LMS] [5/9] Extracting libnghttp2-1.48.0: 100%
[LMS] [6/9] Installing libssh2-1.10.0_1,3...
[LMS] [6/9] Extracting libssh2-1.10.0_1,3: 100%
[LMS] [7/9] Installing libpsl-0.21.1_6...
[LMS] [7/9] Extracting libpsl-0.21.1_6: 100%
[LMS] [8/9] Installing ca_root_nss-3.86...
[LMS] [8/9] Extracting ca_root_nss-3.86: 100%
[LMS] [9/9] Installing curl-7.88.1...
[LMS] [9/9] Extracting curl-7.88.1: 100%
Message from ca_root_nss-3.86:
FreeBSD does not, and can not warrant that the certification authorities
whose certificates are included in this package have in any way been
audited for trustworthiness or RFC 3647 compliance.
Assessment and verification of trust is the complete responsibility of the
system administrator.
This package installs symlinks to support root certificates discovery by
default for software that uses OpenSSL.
This enables SSL Certificate Verification by client software without manual
intervention.
If you prefer to do this manually, replace the following symlinks with
either an empty file or your site-local certificate bundle.
* /etc/ssl/cert.pem
* /usr/local/etc/ssl/cert.pem
* /usr/local/openssl/cert.pem
root@LMS:~ # curl -A "audiodigitale" -o /usr/local/bin/lms_installer
https://audiodigitale.eu/repo/freebsd/lms_installer
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 155k 100 155k 0 0 100k 0 0:00:01 0:00:01 --:--:-- 100k
root@LMS:~ # chmod +x /usr/local/bin/lms_installer
root@LMS:~ # lms_installer
Logitech Media Server installation manager
4. Exit
Available versions:
1- Logitech Media Server 8.0.0
Installing version: 8.0.0
===> Installing dependencies...
FreeBSD repository is up to date.
The following 3 package(s) will be affected (of 0 checked):
lame: 3.100_4
libiconv: 1.17
libogg: 1.3.5,4
Number of packages to be installed: 3
The process will require 5 MiB more space.
1 MiB to be downloaded.
[LMS] [1/3] Fetching libiconv-1.17.pkg: 100% 623 KiB 637.6kB/s 00:01
[LMS] [2/3] Fetching libogg-1.3.5,4.pkg: 100% 192 KiB 197.0kB/s 00:01
[LMS] [3/3] Fetching lame-3.100_4.pkg: 100% 357 KiB 365.7kB/s 00:01
[LMS] [1/3] Installing libiconv-1.17...
[LMS] [1/3] Extracting libiconv-1.17: 100%
[LMS] [2/3] Installing libogg-1.3.5,4...
[LMS] [2/3] Extracting libogg-1.3.5,4: 100%
[LMS] [3/3] Installing lame-3.100_4...
[LMS] [3/3] Extracting lame-3.100_4: 100%
===> Adding slimserv user and group...
===> Creating Logitech Media Server folders...
===> Fixing permissions...
===> Downloading the latest version of Logitechmediaserver...
===> Setting up folder permissions...
Do you want to start Logitech Media Server at boot? (0 = no; 1 = yes)?
Logitech Media Server is installed, if you find any bug or something is not working as it should please contact me at
4. Exit
4
Goodbye!
root@LMS:~ # pkg install portmaster
The following 1 package(s) will be affected (of 0 checked):
portmaster: 3.22
Number of packages to be installed: 1
42 KiB to be downloaded.
[LMS] [1/1] Fetching portmaster-3.22.pkg: 100% 42 KiB 42.6kB/s 00:01
[LMS] [1/1] Installing portmaster-3.22...
[LMS] [1/1] Extracting portmaster-3.22: 100%
root@LMS:~ # portmaster audio/logitechmediaserver
4. Exit
3
4. Exit
3
Current installer version: 21-08-2021. No updates available!
===> Checking Logitech Media Server updates ...
Current logitechmediaserver version: 19-01-2023. No updates available!
4. Exit
4
Goodbye!
root@LMS:
Thanks for looking at this
