Login hanging on pc but not on iphone
BrumbyZ
Hi, today i installed truenas core on a laptop i was not using, installed with uefi, i can login to the webui on the phone even if it's connected to the wifi of the access point that is set in router mode (check "drawing), but when i try to use webui on the "PC" (check drawing) it gets stuck after entering the credentials (check photo ) , could you help me cause i tried searching tons of posts in this forum but nothing meet my problem
BrumbyZ
chrome console errors and warnings:
main-es2016.345644bcd8ec37b11f7b.js:1 WebSocket connection to 'ws://192.168.1.161/websocket' failed: Unrecognized frame opcode: 3
connect @ main-es2016.345644bcd8ec37b11f7b.js:1
main-es2016.345644bcd8ec37b11f7b.js:1 WebSocket connection to 'ws://192.168.1.161/websocket' failed: One or more reserved bits are on: reserved1 = 1, reserved2 = 0, reserved3 = 0
main-es2016.345644bcd8ec37b11f7b.js:1 WebSocket connection to 'ws://192.168.1.161/websocket' failed: Invalid frame header
main-es2016.345644bcd8ec37b11f7b.js:1 WebSocket connection to 'ws://192.168.1.161/websocket' failed: One or more reserved bits are on: reserved1 = 0, reserved2 = 1, reserved3 = 1
signin:1 Failed to decode downloaded font: http://192.168.1.161/ui/Roboto-Medium.32be89b11725274cd3e8.ttf
signin:1 OTS parsing error: invalid sfntVersion: 0
BrumbyZ
maybe this can help
neofusion
It sort of looks like you have double NAT going on there.
Does anything change if you move the TN-laptop to the same router your PC is connected to?
BrumbyZ
no not trying to expose it to the internet, just trying to have access from the pc which is connected to the second router, is this a problem that i don't know?
neofusion
Double NAT is generally not great, it interferes with connectivity. But this issue seems to be caused of something different.
A guess would be an overzealous antivirus program.
You're not running ESET NOD32 by any chance?
BrumbyZ
Double NAT is generally not great, it interferes with connectivity. But this issue seems to be the cause of something different.
no, just running windows defender
Davvo
neofusion
Since it works on other devices but not on the PC, it points to an issue with the PC itself.
You have installed something on the PC that is interfering with connections.
@BrumbyZ
You need to eliminate double NAT
Options are:
1. Replace second router with an Ethernet switch
2. Connect LAN cable from ISP router to LAN port on second router, and connect all other clients to LAN ports, i.e. do not use WAN port on second router.
BrumbyZ
@BrumbyZ
Options are:
i would like to use option 2, will it automatically pick up internet from the lan port or do i need to go from 2nd router control panel?
