Log in from truenas docker DHCP
sixdas
Hi everyone, I have my nas with TrueNAS-SCALE-22.02.3 installed
I have various applications installed including Home Assistant configured in DHCP.
I noticed that from truenas it is not possible to access or ping the ip assigned to the homeassistant docker.
How can I solve?
Thank you
indivision
This worked for me with a default install of Home Assistant:
nc -vz YOUR-STATIC-SERVER-IP 20810
sixdas
Hi, I didn't understand how to use your command.
I'll explain better what I would like to do.
I installed truenas scale, then I created various Dockers including that of home assistant, I set as static ip so that I can scan the network for new devices.
Now I have installed an ups on truenas, and I would like to access it via the NUT integration from home assistant. But from what I understand if I set up a docker with static ip, I can't communicate with truenas also I would also like to use the integration of truenas from home assistant, but for the same reason it doesn't work for me.
I don't know if I got the idea
justjasch
u need to set a bridge, without vm´s and apps can not connect direct to Truenas Host (if in the same IP Range)
u create a bridge on "main" network nic, and u need to move the main ip to the bridge.(all connections going over the bridge)
dont forget to switch apps to the bridge.
sixdas
Hi, I tried your configuration I removed the dhcp check from my eno1 network card, I created the bridge and I put it as per your screen. Then I applied the changes but it didn't work, the apps kept running while it was no longer accessible truenas than in my things and 192.168.78.210.
After a few minutes everything is back to normal, I believe that truenas has not applied the change because I no longer have the bridge connection.
Am I wrong something?
sixdas
Nobody knows how to help me. I tried to create a bridge, but if I save the configuration it does not pass the tests and after 60 seconds it reverts to the previous configuration. Looking online, the steps I carry out seem correct.
Has anyone had the same problem as me and solved it?
Thank you
