codyf51
- Feb 11, 2017
So I have a total of 6 NIC's, 1 IPMI, 2 Built in Intel, a 2 port RealTrek PCIe card, and a QSFP DAC 40G PCI card. All the ethernet ports work as I have used them for jails. The QSFP NIC is new but I am getting a data-link and FreeNAS sees it.
So I want to setup link Aggregation for all four ethernet ports, with two vLan's, LAN and a management LAN for the GUI. The QSFP is going to be used for a ESXi server to target iSCSi on FreeNAS. My problem is that anytime I configure any network setting I'm immediately locked out of the GUI and the server goes off the network. I verified that It was not simply a IP change. The only exception is when I change global settings. My solution is to reset the NIC's via console.
I have watched and read several tutorials and I do not believe that I'm doing anything wrong. Below are a few screenshots of my current config before I make any changes. One thing that is very suspicious is that when I make a change, for example clicking OK to add link aggregation I never receive a warning that this could disrupt network connectivity like others do in the guides. Instead my server just goes offline, completely on all NIC's. Right now I'm only using two ports em0 LAN & GUI, re0 NextCloud Jail to DMZ. While I must point out that I have never setup LACP and I hope this is just a case of nube user, I have no idea what could be wrong. O... Almost forgot my switch is a Unifi 24 port smart switch that supports vLan's and Link Aggregation.
I tera-appreciate any help! :)
FreeNAS Build
Build FreeNAS-9.10.2-
Platform Intel(R) Xeon(R) CPU E5-2670 0 @ 2.60GHz
Memory 65472MB
FreeNAS Build
Memory 65472MB
