root@storage:~ # /mnt/tank/scripts/deploy-freenas/deploy_freenas.py
Certificate import successful
Certificate list successful
Setting active certificate successful
File "/usr/local/lib/python3.6/site-packages/urllib3/connection.py", line 141, in _new_conn
(self.host, self.port), self.timeout, **extra_kw)
File "/usr/local/lib/python3.6/site-packages/urllib3/util/connection.py", line 83, in create_connection
raise err
File "/usr/local/lib/python3.6/site-packages/urllib3/util/connection.py", line 73, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 61] Connection refused
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 601, in urlopen
chunked=chunked)
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 346, in _make_request
self._validate_conn(conn)
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 850, in _validate_conn
conn.connect()
File "/usr/local/lib/python3.6/site-packages/urllib3/connection.py", line 284, in connect
conn = self._new_conn()
File "/usr/local/lib/python3.6/site-packages/urllib3/connection.py", line 150, in _new_conn
self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x807ebf198>: Failed to establish a new connection: [Errno 61] Connection refused
File "/usr/local/lib/python3.6/site-packages/requests/adapters.py", line 440, in send
timeout=timeout
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 639, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/local/lib/python3.6/site-packages/urllib3/util/retry.py", line 388, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='storage.XXX.net', port=443): Max retries exceeded with url: /api/v1.0/services/ftp/ (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x807ebf198>: Failed to establish a new connection: [Errno 61] Connection refused',))
File "/mnt/tank/scripts/deploy-freenas/deploy_freenas.py", line 142, in <module>
"ftp_ssltls_certfile": cert,
File "/usr/local/lib/python3.6/site-packages/requests/api.py", line 126, in put
return request('put', url, data=data, **kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/api.py", line 58, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 508, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 618, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/adapters.py", line 508, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='storage.XXX.net', port=443): Max retries exceeded with url: /api/v1.0/services/ftp/ (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x807ebf198>: Failed to establish a new connection: [Errno 61] Connection refused',))
Certificate is imported in the webgui and working. Doesn't matter if I've the ftp plugin enabled or disabled. I've commented out that part of the code and it works.
and enter my credentials, it works.
