Hi everyone,
I am trying to transfer around 1.10 tb (150,000 files), from a volume mounted as a disk to a Windows VM, to a mounted share in that Windows VM.
Small transfers work fine, but with this transfer, it pauses from time to time, with the error “Too many files are currently in use. Quit one or more programs, and then try again.” Most of the time when trying again, the transfer continues. The VM resources don’t seem to be a problem.
From time to time when the transfer is no longer working with “trying again”, I noticed access to the share was lost from that VM, if I try to access the share through another computer it works.
I have TrueNAS configured with a bridge connecting the main interface and have a static IP. MTU is set to 1500, and I have no idea if this should be changed. I had to use a bridge to access the shares within VMs (I read that was the way of doing it). By the way, my nameserver is set to 1.1.1.1
I’ve gone through a lot of settings, permissions, default share parameters, instead of generic SMB, and much more, and I'm exhausted :(
I am currently testing doing a similar transfer but from another computer, I am copying an almost exact copy of the data to another Share, this is an ongoing test…
Another thing that I noticed is some weird errors on the main console, here you can take a look at the debug info, and some screenshots
https://www.dropbox.com/sh/wytxuyrk9d62kr4/AADQjf9vwun_48o92aFSVNTra?dl=0
I am also having a SMART notification, but when performing LONG SMART test, they appear to have no errors, investigating with scrutiny, they appear to be ok
My setup:
Permissions
Owner:
admin
Group:
Admin
Type:
FILESYSTEM
Sync:
STANDARD
Compression Level:
Inherit (LZ4)
Enable Atime:
OFF
ZFS Deduplication:
OFF
Case Sensitivity:
ON
I appreciate all your support!
- Device: /dev/sdd, SMART Failure: WARNING: ascq=0x96.
- Device: /dev/sdb, SMART Failure: WARNING: ascq=0x96.
My setup:
- Dell PowerEdge T430 BIOS 2.16.0
- 2 x 16 Gb ECC DDR4 1866 Mhz
- 2 x Intel Xeon E5-2620 v3 @ 2.4GHz
- 8 x 4tb SAS 6 GiBit 7200 RPM HGST HUS724040ALS640 RZ-2 Vdev
- Dell PERC H730 in HBA mode
- 2 x Integrated Broadcom Gigabit Ethernet BCM5720
- 2 x 120 Gb Sata SSD mirrored boot drive (Consumer Grade)
- 2 x 512 nvme m2 drives (Consumer grade) striped vdev
- TrueNAS Scale 22.12.0
- I have cloudflared to remote access some stuff trough a tunnel
Permissions
Owner:
admin
Group:
Admin
Type:
FILESYSTEM
Sync:
STANDARD
Compression Level:
Inherit (LZ4)
Enable Atime:
OFF
ZFS Deduplication:
OFF
Case Sensitivity:
ON
