Lansweeper (or similar alternative)
SecCon
Does anyone have Lansweeper running and would you be kind enough to share how you installed it?
I assume > jail > windows host > lansweeper. Any other way?
Used it for ages and consider it extremely useful, got the agent installed on all my windows machines, but I am open for alternatives. I will need to setup a Windows Host regardless.
Patrick M. Hausen
The installation requirements state that this software runs on Windows exclusively. What would you put in the jail?
SecCon
A virtual Windows.
Unless someone has found another way. If not, then it's fine. I can run it from there.
I thought you could/should use Jails for VM,s but it seems it is not necessary...
Patrick M. Hausen
Jails and VMs run different things. Jails are for native FreeBSD applications, e.g. Nextcloud. You can run a Windows VM with that software on TrueNAS.
