Hi everyone,
When writing multiple files (in one thread) to the FreeNAS server over NFS,RSYNC,SCP or other measures, the file transfer speed is superb, however in between the first files ending, and the starting of the next, there is a 2-3 second pause.
If i transfer a 100MB file, it takes less than 1 second to transfer the file, however the entire filesystem then locks up for about 2-3 seconds. All other threads running towards the ZFS volume are also paused for those seconds.
Both LSI cards are flashed with newest IT firmware, all settings are left as default. Raid is a RAIDZ3 with 12 disks. Has anyone had similar problems before? I'm not sure if i need to start troubleshooting the hardware or software first..
Hardware info:
Operating system type: FreeBSD
Operating system release: 9.2-RELEASE-p3
Operating system revision: 199506
Kernel version: FreeBSD 9.2-RELEASE-p3
Machine class: amd64
System architecture: amd64
Machine model: Intel(R) Xeon(R) CPU E5440 @ 2.83GHz
Number of active CPUs: 4
Number of CPUs online: 4
Current CPU frequency: 2.77 Ghz
Physical Memory: 31.98 GiB
mps0@pci0:3:0:0: class=0x010700 card=0x30201000 chip=0x00721000 rev=0x03 hdr=0x00
vendor = 'LSI Logic / Symbios Logic'
device = 'SAS2008 PCI-Express Fusion-MPT SAS-2 [Falcon]'
class = mass storage
subclass = SAS
mps1@pci0:9:0:0: class=0x010700 card=0x30201000 chip=0x00721000 rev=0x02 hdr=0x00
subclass = SAS
Hardware info:
subclass = SAS
subclass = SAS
