L2ARC Mirrors
wreedps
Can you not mirror L2ARC drives?
BigDave
FreeNAS Enthusiast
wreedps
Thank you for confirming.
jgreco
Resident Grinch
Yeah, there's no particular reason you would want to do this, though you certainly can configure ZFS to do that.
wreedps
I am not going to do it if it is not recommended.
jgreco
Resident Grinch
It isn't that it's not "recommended". It's merely pointless. The data in the L2ARC already exists on your pool, so if you can afford two devices for L2ARC, you're better off using them separately and getting twice the L2ARC capacity.
wreedps
Got it, thanks!
