Question, I spun up a few pods (sabnazb, lidarr, etc., stack). The issue I have is that I have a FW rule that routes specific hosts through a VPN (wg0). I have assigned specific IPs to those pods and work fine however, the FW still thinks they are sourcing from the host (TrueNAS SCALE), resulting in not routing through VPN/wg0). I assume this has something to do w/ the internal network on kubernetes. Still trying to adjust/learn, any suggestions moving forward?
Also, I can access the apps via the static IP defined on the pods, but my FW thinks they are sourcing from the host/TrueNAS Scale and will not route correctly over the VPN/wg0 interface. Of course if I add the host/TrueNAS SCALE to the FW alias for routing over the VPN/wg0 that works just fine, just the pods will not, even though they have a specific IP on the same subnet and defined in the FW alias.....
