specter9mm
- Apr 21, 2023
I am trying find out if my interface setup is correct, or I have done something wrong. I see this message is my logs quite often. Right now I have two 10g fiber links in a bond, without an ip address assigned, and a bridge set up with the bond0 interface as the parent. I assigned this truenas scale box 1 static ip address on the bridge interface. Should the ip address be on the bond0 interface instead? Will the bridge continue to work without any ip address assigned?
kernel: br0: received packet on bond0 with own address as source address (addr:ba:a1:9b:f6:ea:39, vlan:0)
