kernel boot parameter - How to add to TN Scale?
flashdrive
midclt call system.advanced.update '{"kernel_extra_options": "xhci_hcd.quirks=270336"}'
flashdrive
@sretalla
Thank you.
For one time application of the parameter I would enter "xhci..." at the boot selection of TN Scale, I presume?
Or is there a web interface of TN S where to add this?
You run that in the shell while the server is running. It's then saved to the database and will be enacted to the GRUB_CMDLINE_LINUX_DEFAULT for reboot.
Not as far as I know at the moment.
flashdrive
@sretalla
Thank you very much again - it worked like a charm.
Is there any chance that this can be reported to ix systems to add this by default?
The "report a bug" link at the top of the page.
