jfa-go available ?
Vision
Hi, I'm looking for a way to install this app on my system Jfa-go. Unfortunately, this app is not available in the Appstore. Do I need a special catalog or can the app also be installed manually?
TrueNAS-SCALE-22.12.2
Would be great if someone has a tip.
Thanks and best regards
jgreco
Resident Grinch
"Create a container and install it within the container" would seem to be the best option. Jellyfin and Emby aren't as popular around here as Plex, but you might draw some converts.
jgreco
Resident Grinch
Oh, sorry, that's probably a better answer. I don't use TrueCharts so I wasn't aware of it.
Vision
Thx for your help guys !
I am testing a little bit, but i have issues with the ip adress..
I was pulling the docker image from docker hub, config it and started but i have no ip…
Anybody know the right network config to resolve this to my “true nas“ IP ?
thx
best regards Vision
in that screen, 0.0.0.0 represents the IP of your NAS (if you chose to publish the ports of the app).
yapkoloi
Hai all,
It's working fine? If yes, please share tutorial how to install on my truenas scale.
Thanks.
