BUILD JBOD Set Drive Volumes Don't Post In FREENAS
united
Completely Fresh hardware system and clean install of FreeNAS 10
FreeNAS 10 latest as of Feb 20th (US time)
Chassis: Supermicro 6048R-E1CR36H
RAID Controller: LSI3108 HW RAID
SATA Connected 24 x 8TB Drives
Drives are all set to JBOD not RAID and are completely new out of the bags
All drives are posting in BIOS with JBOD status, however I don't see these as available volumes inside FreeNAS
FYI, I am a nooby to FreeNAS and I may have missed a completely obvious step to have volumes show inside of FreeNAS.
Model Numbers for Hardware Build:
WD8002FRYZ WD Gold Edition,Enterprise 8TB 3.5 inch HDD, 128MB Cache ,7200 RPM SATA3 Hard Drive
SSG-6048R-E1CR36H Supermicro 6048R-E1CR36H Barebone 1 4,830.59 SuperStorage Server, 4U, 2x
LGA2011-3, 36x 3.5" Hot-Swap SAS3/SATA3,
LSI3108 HW RAID and expander backplanes, 2x 10GbE X540, 2x 1280W Redundant PSU
CT16G4DFD8213 Crucial 16GB DESKTOP DDR4 2133 MT/s 4 129.00 (PC4-17000) CL15 DR x8 Unbuffered DIMM 288pin DDR4 Platform ONLY
BX80644E52620V3 Intel Xeon E5-2620 v3 Processor,2.4GHz, 15MB 2 570.00 Cache, LGA2011-3, 6Core/12Thread,85W TDP
MFM1T02A-SR Mellanox optical module, ETH 10GbE, 10Gb/s, 2 144.79 SFP+, LC-LC, 850nm, SR up to 300m
MCX312B-XCCT Mellanox MCX312B-XCCT ConnectX-3 Pro EN 1 270.83 network interface card, 10GbE, dual-port SFP+, PCIe3.0 x8 8GT/s, RoHS R6
There are a lot of things wrong here.
These two don't mix. Do not run beta software unless you know what you're doing.
If you can't get rid of that thing and use an SAS3008, SAS2308 or SAS2008 in IT mode, the next-best thing is to stop using the archaic mfi driver and instead use the new mrsas driver, which does allow compatible SAS controllers (SAS3xxx and SAS2308) to present direct-attach drives to the OS even in HW RAID mode. You'll have to search the forum to find the correct procedure.
That's not ECC RAM. Given the rest of the system, I assume this was a mistake, so replace these with ECC DIMMs.
united
@Ericloewe I will investigate these hardware suggestions via our reseller this week. I really appreciate your input! : )
Mr_N
Much better :)
Stux
Check that you have ECC ram for a build of that class.
