Jails on Core 13.0-U5.2 do not connect to the internet
BuffTofu
Can you create a new test jail, and see if DNS works under the test jail?
To add on to this, one of my jails, as you may have seen, is Homebridge, and was installed via the Plugins page. If I try to install any plugin, it tries to connect it to pkg and fails to, which is the same reason why it can't ping domains. I doubt it is a configuration issue.
Whattteva
So, now you're back from U5 to U3 and it still doesn't work? Then it sounds like it probably wasn't the upgrade and something else that caused it that may have been catalyzed by the reboot.
BuffTofu
I don’t know. But the screen now just shows this
Davvo
Davvo
Davvo
BuffTofu
Your bridge interface doesn't have an IP.
I saw no change with or without one. Is the bridge its own device, or does it share an IP with the jail? I have had 2 jails running on 1 bridge and it worked fine.
Davvo
In TN you can assign jails and VMs to a network interface, be it a bridge or a phisical one.
@Patrick M. Hausen has already told you the proper way it should be configured.
I don't have a "bridge0" interface in the TrueNAS Core GUI. It only exists when checking with "ifconfig" in the command-line.
Did you manually create the "bridge0" interface using the GUI?
In my case, the bridge is configured per each jail.
For example, a jail will use re0 as the vnet_default_interface, and then under Network Properties the interfaces is vnet0:bridge0
In summary:
  • Before creating any jails, the TrueNAS Core GUI shows the physical network cards that you can configure for the server itself
  • No need to manually create a bridge interface (i.e, "bridge0") in the GUI
  • When you create and configure a jail to use VNET, and assign it a vnet_default_interface (i.e, "re0"), it should automatically create a bridge interface (which will still not show up in the GUI; only in the command-line)
  • You can then confirm this by checking the jail's Network Properties and even using "ifconfig" to check in an SSH session
EDIT:
This might mean you'd have to stop all your jails, then delete "bridge0" via the GUI -> Network -> Interfaces
Then while your jails are still down, configure them to use "re0" as the vnet_default_interface and to use vnet0:bridge0 in its Network Properties for "interfaces"
Then start your jails to finish the process.
Sasquatch
13-u5.3 definitely breaks jail networking.
After upgrade from 5.2 to 5.3 all jails networking stopped working, revert to 5.2 fixes it without any config changes.
in 5.3 newly created jails don't work, not in NAT not VNET,
DHCP fails to acquire address
Manual IP assignment results with no connection at all, can't ping host, can't ping other jails, just a black hole.
All my jails are and always were configured as per winnielinne last post.
only change in networking from fresh install is "gateway_enable" tunable and fixed IP for main network interface
ifconfig in jail both 5.3 and 5.2 show the same:
ifconfig
    options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
    inet6 ::1 prefixlen 128
    inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
    groups: lo
pflog0: flags=0<> metric 0 mtu 33160
    groups: pflog
epair0b: flags=8863<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
    options=8<VLAN_MTU>
    ether 46:8a:5b:0e:ad:6e
    hwaddr 02:26:2f:2b:f1:0b
    inet 192.168.1.155 netmask 0xffffff00 broadcast 192.168.1.255
    groups: epair
    status: active
    nd6 options=1<PERFORMNUD>
Patrick M. Hausen
Output of ifconfig on the host, please.
Sasquatch
that's from 5.2
ifconfig
igb0: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
    options=4a500b9<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,VLAN_HWFILTER,VLAN_HWTSO,RXCSUM_IPV6,NOMAP>
    ether 44:8a:5b:f5:a3:ca
    inet 192.168.1.120 netmask 0xffffff00 broadcast 192.168.1.255
    media: Ethernet autoselect (1000baseT <full-duplex>)
    status: active
igb1: flags=8822<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
    options=4e507bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,VLAN_HWFILTER,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6,NOMAP>
    ether 44:8a:5b:f5:a3:cb
    status: no carrier
    inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3
    groups: lo
    groups: pflog
    ether 58:9c:fc:10:ff:9b
    member: vnet0.4 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
            ifmaxaddr 0 port 10 priority 128 path cost 2000
    member: vnet0.3 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
            ifmaxaddr 0 port 7 priority 128 path cost 2000
    member: vnet0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
            ifmaxaddr 0 port 6 priority 128 path cost 2000000
    member: igb0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
            ifmaxaddr 0 port 1 priority 128 path cost 20000
    groups: bridge
vnet0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
    options=80000<LINKSTATE>
    ether fe:a0:98:3a:25:8a
    hwaddr 58:9c:fc:10:b9:32
    groups: tap
    status: active
    Opened by PID 1780
tun0: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> metric 0 mtu 1500
    inet 10.10.0.1 --> 10.10.0.2 netmask 0xffffff00
    groups: tun
    Opened by PID 2104
tun1: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> metric 0 mtu 1500
    inet 10.8.0.2 --> 10.8.0.1 netmask 0xffffff00
    groups: tun
    Opened by PID 2065
vnet0.3: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
    description: associated with jail: cloud as nic: epair0b
    options=8<VLAN_MTU>
    ether 44:8a:5b:07:4c:d6
    hwaddr 02:77:9e:58:90:0a
    groups: epair
    status: active
vnet0.4: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
    description: associated with jail: DB as nic: epair0b
    options=8<VLAN_MTU>
    ether 46:8a:5b:99:66:bc
    hwaddr 02:bf:81:c2:32:0a
    groups: epair
    status: active
and 5.3
 ifconfig
    status: active
    status: no carrier
    groups: lo
    groups: pflog
            ifmaxaddr 0 port 12 priority 128 path cost 2000
    member: vnet0.2 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
    member: vnet0.1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
    groups: bridge
vnet0.1: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
    options=8<VLAN_MTU>
    hwaddr 02:89:e7:0f:56:0a
    groups: epair
    status: active
bridge1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
    ether 58:9c:fc:10:ff:fd
            ifmaxaddr 0 port 8 priority 128 path cost 2000000
    groups: bridge
    groups: tap
    status: active
    Opened by PID 1823
    groups: tun
    Opened by PID 2227
vnet0.2: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
    description: associated with jail: db-copy as nic: epair0b
    options=8<VLAN_MTU>
    ether 46:8a:5b:0e:ad:6d
    hwaddr 02:7a:15:62:34:0a
    groups: epair
    status: active
    groups: tun
    Opened by PID 2058
    options=8<VLAN_MTU>
    groups: epair
    status: active
Patrick M. Hausen
igb0 is missing from the bridge interface. And your configuration is invalid even with U5.2. The IP address must be on the bridge0, not on igb0.
- reboot with all jails autostart disabled
- create an interface of type bridge named bridge0
- add igb0 as the only member interface
- remove the IP address from igb0, instead put "up" into the options field
- put the IP address on bridge0
- test and save - you should increase the timeout from 60 to e.g. 300 seconds before clicking "test", then clear the ARP cache of your desktop system
If that worked, then for each jail:
- vnet_default_interface: none
The rest looks good. Your jails should work afterwards.
Patrick M. Hausen
P.S. Temporary fix for U5.3: ifconfig bridge0 addm igb0
Permanent fix: see my last post above.
Sasquatch
thannk you Sir.
its odd it worked for some 5 years since 11u1 and now stopped...
I'll implement changes later and see if it works in 5.3, its a live production system so can't f-about too much ion business hours.
