@dmshimself What's the output of
ifconfig immediately after a reboot? Where your jails originally recreated via iocage?
At the shell/CLI what is out of
iocage get boot <jailname>
Here's an example:
root@freenasv[~]# iocage list
| JID | NAME | STATE | RELEASE | IP4 |
| - | LMS | down | 11.2-RELEASE | 192.168.0.60 |
| - | dokuwiki | down | 11.2-RELEASE | 192.168.0.61 |
| 2 | plex | up | 11.2-RELEASE | 192.168.0.69 |
| 1 | transmission | up | 11.2-RELEASE | 192.168.0.59 |
root@freenasv[~]# iocage get boot plex
on
root@freenasv[~]# iocage get boot dokuwiki
off
root@freenasv[~]#
Hi on the NAS the ifconfig looks like this:
bge0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1350
options=c0099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,VLAN_HWTSO,LINKSTATE>
ether 9c:b6:54:0b:18:56
hwaddr 9c:b6:54:0b:18:56
inet6 fe80::9eb6:54ff:fe0b:1856%bge0 prefixlen 64 scopeid 0x1
inet6 2a00:1508:a0d:fe00:9eb6:54ff:fe0b:1856 prefixlen 64 autoconf
inet 10.13.65.20 netmask 0xffff0000 broadcast 10.13.255.255
inet 10.13.200.0 netmask 0xffff0000 broadcast 10.13.255.255
nd6 options=23<PERFORMNUD,ACCEPT_RTADV,AUTO_LINKLOCAL>
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2
groups: lo
bridge0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1350
ether 02:39:20:24:a2:00
nd6 options=1<PERFORMNUD>
groups: bridge
member: vnet0:13 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 6 priority 128 path cost 2000
member: vnet0:12 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 3 priority 128 path cost 2000
member: tap0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 14 priority 128 path cost 2000000
member: vnet0:8 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 11 priority 128 path cost 2000
member: vnet0:6 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 9 priority 128 path cost 2000
member: vnet0:5 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 4 priority 128 path cost 2000
member: bge0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 1 priority 128 path cost 20000
vnet0:5: flags=8942<BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1350
description: associated with jail: home assistant
options=8<VLAN_MTU>
ether 02:ff:60:97:c6:a5
hwaddr 02:72:10:00:04:0a
status: active
groups: epair
epair0b: flags=8842<BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1350
options=8<VLAN_MTU>
ether 02:ff:60:97:c6:a6
hwaddr 02:72:10:00:08:0b
status: active
vnet0:6: flags=8942<BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1350
options=8<VLAN_MTU>
hwaddr 02:72:10:00:09:0a
status: active
groups: epair
vnet0:8: flags=8942<BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1350
options=8<VLAN_MTU>
hwaddr 02:72:10:00:0b:0a
status: active
groups: epair
tap0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1350
options=80000<LINKSTATE>
ether 00:bd:c2:a5:55:00
hwaddr 00:bd:c2:a5:55:00
status: active
groups: tap
Opened by PID 33413
vnet0:12: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1350
options=8<VLAN_MTU>
hwaddr 02:72:10:00:03:0a
inet6 fe80::ff:60ff:fe97:c6a5%vnet0:12 prefixlen 64 scopeid 0x3
status: active
groups: epair
vnet0:13: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1350
description: associated with jail: syncthing
options=8<VLAN_MTU>
ether 02:ff:60:5b:07:f8
hwaddr 02:72:10:00:06:0a
status: active
groups: epair
The jails were origonally created with iocage in 11.1 before the upgrade to 11.2 So I did all the iocage work manually in 11.1
The list of jails lis shown below. The sample I'm using is mythtv-backend and autostart appears to be on:
iocage get boot mythtv-backend
on
| 12 | home assistant | up | 11.2-RELEASE | DHCP |
| 14 | mythtv-backend | up | 11.2-RELEASE | 10.13.200.0 |
| - | mythtv-test | down | 11.2-RELEASE | 10.13.200.1 |
| - | mythtvjail | down | 11.2-RELEASE | 10.13.200.0 |
| 13 | syncthing | up | 11.2-RELEASE | DHCP |
