Hello there,
I have a jail, which I want to connect to a VLAN. I added two VLANs (id 1 and 2 with interfaces vlan1 and vlan2). I configured FreeNAS to obtain an IP on vlan1. This works without a problem. I left the em0 and vlan2 interfaces unconfigured, except for "up" in the options field. I followed https://forums.freenas.org/index.php?threads/how-to-set-separate-vlan-for-jail.54019/ and inserted "vlan2" into "/mnt/pool0/jails/.newton.meta/iface". In the jail,
As you see the interface doesn't get an IP address. When I run
However, another
What am I missing?
ifconfig outputsCode:
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6> inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1 inet 127.0.0.1 netmask 0xff000000 nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL> groups: lo epair2b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8<VLAN_MTU> ether 02:ff:ff:00:0c:0b inet 0.0.0.0 netmask 0xff000000 broadcast 255.255.255.255 inet6 fe80::ff:ffff:fe00:c0b%epair2b prefixlen 64 scopeid 0x2 nd6 options=23<PERFORMNUD,ACCEPT_RTADV,AUTO_LINKLOCAL> media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active groups: epair
dhclient epair2b it seems like the interface gets an IP:Code:
DHCPREQUEST on epair2b to 255.255.255.255 port 67 DHCPACK from 10.1.0.1 bound to 10.1.0.4 -- renewal in 300 seconds.
However, another
ifconfig gives the same output as before, i.e. no IP address.What am I missing?
